Discuss
Hotpoint Icemaker problem
 in
Refrigerator & Freezer Repair
My icemaker has quit. The supply line was blocked at the shutoff valve. I cleaned it out and am getting
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Hotpoint Icemaker problem
  #1 (permalink)
Old 06-01-2008, 05:34 PM
usmailman956 usmailman956 is offline
Junior Member
usmailman956 is on a distinguished road
Default Hotpoint Icemaker problem
Model Number: cst18g   Brand: Hotpoint   Age: More than 10 years
My icemaker has quit. The supply line was blocked at the shutoff valve. I cleaned it out and am getting water to the water valve on the back of refrigerator. We used to get hollow cubes and water freezing in collection tray for cubes. I have gotten a few very small (like 1/4 size) cubes out of machine after cleaning supply line entry. This fridge has been very reliable and I have had to replace water valve once before, but it didn't act like this. HELP! with summer coming on we need ice
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-01-2008, 06:47 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a clogged screen in the water inlet valve and probably this water inlet valve needs to be replaced.
I'm not able to provide more accurate advise due to the model number you posted does not come up.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 06-02-2008, 06:23 PM
Junior Member
Default hotpoint icemaker
I checked the inlet screen it was clean, since last post the thing has freed up and started working except for some of the cubes are still coming out hollow.Model number is ctx18gjb it is several years old.
  #4 (permalink)
Old 06-02-2008, 09:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
One of most common cause for hollow ice cubes is insufficient amount of water.
Did you buy the fridge with the ice maker or it was installed later?
The break down diagrams for this model does not show any ice maker nor a water valve.
Here are the break down diagrams for the Hotpoint refrigerator Model CTX18GJBR
__________________
  #5 (permalink)
Old 06-03-2008, 06:25 PM
Junior Member
Default
I purchased it with the icemaker from the factory. The cubes are good size but some are hollow. Also the tray seems to have water in it and the cubes stick together and freeze. It almost seems as if the cubes get ejected from maker before they freeze enough
  #6 (permalink)
Old 06-04-2008, 01:36 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Does it have the green LED?
If it does not then remove the front cover and look for the adjustment screw. Turn it about 1/2 turn CCW to increase amount of water.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Icemaker problem Hilton Refrigerator & Freezer Repair 25 04-07-2008 04:26 PM
Icemaker Problem dbjackel Refrigerator & Freezer Repair 2 12-17-2007 07:08 PM
Icemaker problem nhfr Refrigerator & Freezer Repair 0 11-17-2007 10:47 PM
icemaker problem kpriest Refrigerator & Freezer Repair 1 08-30-2007 04:53 PM
Sears icemaker problem standback27 Refrigerator & Freezer Repair 0 08-20-2007 02:58 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
