Bosch B20CS50SNS Low Ice Output
Model Number: B20CS505SNS Brand: Bosch Age: 1 - 5 years
Hello,
My Bosch refridgerator is 3 years old. The ice maker output is low. Upon further inspection only 6 of the 10 cube compartments is filling with water. What I have observed is the following. After the ice tray is dumped and the tray is returned I hear the water valve turn on but do not see water come out of the supply tube for a second or two. Then water comes out to fill the tray. Then I hear the valve turn off the water stops imediately. I usually see a small peice of ice come out of the tube with the water. It's no where near the diameter of the tube so I doubt it's a clog. Is there an adjustment for the amount of water supplied to the ice tray? The water pressure looks from the water dispenser appears to be as strong as it ever was.
Ads By Google
Related Models
