Discuss
Refrigerator not cooling freezer fine
 in
Refrigerator & Freezer Repair
The Refrigerator I have seems that the refrigerator part is not cooling. Pulled it out, removed rear panel, vacuumed rear
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator not cooling freezer fine
  #1 (permalink)
Old 03-19-2010, 04:41 PM
Junior Member
Lambert58 is on a distinguished road
Default Refrigerator not cooling freezer fine
Model Number: BX20S5L   Brand: Amana   Age: 5 - 10 years
The Refrigerator I have seems that the refrigerator part is not cooling. Pulled it out, removed rear panel, vacuumed rear and underside. It still seems to not do the job. Removed rear panel in freezer and did not detect any ice buildup.
Ads By Google
Related Models
Amana BX20S5L REF - BOTTOM MOUNTS
Amana BX20S5W REF - BOTTOM MOUNTS
Amana BX21TE REF - BOTTOM MOUNTS
Amana BX21TL REF - BOTTOM MOUNTS
Amana BX21TW REF - BOTTOM MOUNTS
Amana BX21V1C REF - BOTTOM MOUNTS
Amana BX21V1E REF - BOTTOM MOUNTS
Amana BX21V1W REF - BOTTOM MOUNTS
Amana BX21V2C REF - BOTTOM MOUNTS
Amana BX21V2E REF - BOTTOM MOUNTS
Amana BX21V2W REF - BOTTOM MOUNTS
Amana BX21VC REF - BOTTOM MOUNTS
Amana BX21VE REF - BOTTOM MOUNTS
Amana BX21VL REF - BOTTOM MOUNTS
Amana BX21VW REF - BOTTOM MOUNTS
Amana BX22A2E REF - BOTTOM MOUNTS
Amana BX22A2L REF - BOTTOM MOUNTS
Amana BX22A2W REF - BOTTOM MOUNTS
Amana BX22A5L REF - BOTTOM MOUNTS
Amana BX22A5W REF - BOTTOM MOUNTS
Amana BX22R3E REF - BOTTOM MOUNTS
Amana BX22R3L REF - BOTTOM MOUNTS
Amana BX22R3W REF - BOTTOM MOUNTS
Amana BX22RE REF - BOTTOM MOUNTS
Amana BX22RL REF - BOTTOM MOUNTS
Amana BX22RW REF - BOTTOM MOUNTS
Amana BX22S5E REF - BOTTOM MOUNTS
Amana BX22S5L REF - BOTTOM MOUNTS
Amana BX22S5W REF - BOTTOM MOUNTS
Amana BX22TE REF - BOTTOM MOUNTS
Amana BX22TL REF - BOTTOM MOUNTS
Amana BX22TW REF - BOTTOM MOUNTS
Amana BX518VE REF - BOTTOM MOUNTS
Amana BX518VW REF - BOTTOM MOUNTS
Amana BX521VCPER REF - BOTTOM MOUNTS
Amana BX521VCPSR REF - BOTTOM MOUNTS
Amana BX521VCPWR REF - BOTTOM MOUNTS
Amana BX521VE REF - BOTTOM MOUNTS
Amana BX521VW REF - BOTTOM MOUNTS
Amana BXF19TL REF - BOTTOM MOUNTS
Amana BXF19TW REF - BOTTOM MOUNTS
Amana BXI21VE REF - BOTTOM MOUNTS
Amana BXI21VL REF - BOTTOM MOUNTS
Amana BXI21VW REF - BOTTOM MOUNTS
Amana BXI22S5E REF - BOTTOM MOUNTS
Amana BXI22S5L REF - BOTTOM MOUNTS
Amana BXI22S5W REF - BOTTOM MOUNTS
Whirlpool BYCCD3421W0 COMPACT ELECTRIC DYER
Whirlpool BYCCD3421W1 COMPACT ELECTRIC DRYER
Whirlpool BYCCD3421W2 COMPACT ELECTRIC DRYER
Whirlpool BYCCD3421W3 COMPACT ELECTRIC DRYER
Whirlpool BYCCD3921W0 ELECTRIC DRYER
Whirlpool BYCD3722W0 DRYERS
Whirlpool BYCD3722W1 ELECTRIC DRYER
Whirlpool BYCD3723W0 DRYERS
Whirlpool BYCD3723W1 GAS DRYER
Whirlpool BYCD3723W2 DRYER
Whirlpool BYCD4932W0 ELECTRIC DRYER
Whirlpool BYCD4933W0 GAS DRYER
Whirlpool BYCW4271W0 DIRECT-DRIVE WASHER
Whirlpool BYCW6292W0 WASHER
Whirlpool BYCWD6274W0 LAUNDRY COMBINATION UNITS
Whirlpool BYCWD6274W1 WASHER / DRYER COMBINATION UNIT
Whirlpool BYCWD6274W2 WASHER/DRYER COMBO
Whirlpool BYCWD6274W3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool BYCWD6274W4 WASHER/DRYER LAUNDRY SYSTEM
Amana BZ20QE REF - BOTTOM MOUNTS
Amana BZ20QG REF - BOTTOM MOUNTS
Amana BZ20QL REF - BOTTOM MOUNTS
Amana BZ20QW REF - BOTTOM MOUNTS
Amana BZ20R REF - BOTTOM MOUNTS
Amana BZ20RE REF - BOTTOM MOUNTS
Amana BZ20RG REF - BOTTOM MOUNTS
Amana BZ20RL REF - BOTTOM MOUNTS
  #2 (permalink)
Old 03-20-2010, 05:18 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Replacement parts for BX20S5L models | AppliancePartsPros.com
When you did this was there any frost on the coils or only frost on part of the coils which could indicate a freon leak.
Best to measure the temperature in the freezer to ensure that it is close to 0 degrees F.
Soft ice cream is a good indicator of a poor freezer temperature and the fresh food section is very dependent on the freezer temp.
Check to be sure that the evaporator fan in the freezer is running.
It is required to push air up into the fresh food.
If all OK check the damper (Item 6 in Section 8) is open.
This is what regulates the fresh food temperature.
__________________
  #3 (permalink)
Old 03-20-2010, 08:26 AM
Junior Member
Default
Quote:
Originally Posted by denman View Post
When I removed the back panel in the freezer all food was frozen. I don't have ice cream but do have soup that I freeze in plastic container and this was frozen solid.
It's hard to detect if evaporator fan is operating with all sounds that are in the area. Any recommendations?
By the way turned up defrost timer and fan kicked on and looked in freezer and had freezer temp air blowing out freezer grill.
  #4 (permalink)
Old 03-20-2010, 08:47 AM
Junior Member
Default
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
  #5 (permalink)
Old 03-20-2010, 09:41 AM
Senior Expert
APP Volunteer
Default
Which fan turned on?
Also turning the defrost timer should only have turned on the fans and compressor if you were in a defrost cycle and you forced it out of defrost.
__________________
  #6 (permalink)
Old 03-20-2010, 10:24 AM
Junior Member
Default
Both fans did kick on. I also have to retract my statement about freezer temp air blowing out the freezer grill. It seems the air does not come out in a frozen state. Freon low?
  #7 (permalink)
Old 03-20-2010, 12:26 PM
Senior Expert
APP Volunteer
Default
You have to check the coils.
Usually if there is just frost where the freon enters the coils or the frost is patchy, it is an indication of low freon.
Note you have to do this a couple hours after a defrost cycle since the coils will be clear just after defrost.
Another indication of low freon is that the compressor runs continuously.
__________________
  #8 (permalink)
Old 03-20-2010, 01:15 PM
Junior Member
Default
I have to do a check on this.
Another question awhile back we had problems with things freezing up in the crisper drawers what would cause this?
  #9 (permalink)
Old 03-21-2010, 07:39 AM
Senior Expert
APP Volunteer
Default
If the damper started to go bad it could cause this re: sticking open.
You first have to determine the freezer temperature as everything relies on this.
Your soup may not be a good temperature indicator due to it's water content.
Ice cream works because of it's fat content.
__________________
  #10 (permalink)
Old 03-21-2010, 07:59 AM
Junior Member
Default
I think I found out what the problem is. I know early I spoke about the freezer temp but noticed it was on a low temp. I did get the chance to look over the damper. This is the problem. It would only open a little under half way when the dial was turned to full. I pushed the damper manually and it opened even more giving me the additionally cooling that was needed. Order part here I come.
Being the first time I tried this website I greatly appreciated the expert help you have to offer. This saved me alot of money. Have a great day.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator not Cooling but Freezer Fine desertcafe@comcast.net Refrigerator & Freezer Repair 0 07-01-2009 03:08 PM
refrigerator not cooling but freezer works fine spoonman Refrigerator & Freezer Repair 1 10-23-2008 03:11 PM
Refrigerator has quit cooling, but frez works fine. kolby Refrigerator & Freezer Repair 2 08-24-2008 07:11 PM
Freezer fine but refrigertor isn't cooling jbesh Refrigerator & Freezer Repair 0 03-01-2008 06:26 AM
fridge not cooling but freezer is fine jessibadillo Refrigerator & Freezer Repair 5 10-26-2007 07:37 PM
