went to hookup waterline it started leaking at bottom of refrig. took off back panel..it apeared it was leaking from the contol switch.. to be sure i turn water vale on from water supply vale...and say the leak part no#. 2304757...
Question I know I can replace that unite my question is do i need a certain tool the hoses running to it looks as through you can pop it off or it uses a special tool.
Please advise;
Rock1674
