| » Maytag Refrigerator compressor replacement |
Model Number: MSD25556A Brand: Maytag Age: 5 - 10 years
I have a Maytag MSD2556A and the compressor is in lock rotor ..
I ordered a compressor from Appliance Parts Pros and they shipped me a Embraco FGS 100 HAW and the old compressor number is Embraco EGS 100 HLC. The old compressor doesn't have oil cooler connections but the new one does. I talked to a sales associate for your company but she says that that compressor is for the unit. Maybe the oil cooler connections are for other models that have that option on the refrigerator but mine doesn't. My question is can I just seal off the oil cooler connection and have no problems. Thank You in advance |
The oil cooler should have rubber plugs over them, you should not have to do anything with them, only if your gonna use them
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
They are factory sealed out of the box. If they have the rubber caps over the tubes, the refrigerant will not leak out. Some manufacturers put rubber caps, and some put rubber plugs. You leave the plugs or caps if you don't need to braze any copper lines to them.
__________________
Also I ohm-ed out the connector that is suppose to go over the start and run terminals and they ohm together. Sup with that? I haven't installed a small compressor for a refrigerator in years but I guess they have changed things.It has three male terminals on the other side. They gave me a start device that I guess is suppose to go in conjunction with the connector. Not sure how the part would work properly on the terminals if they ohm together. Meaning I have continuity between them. As a matter of fact all three terminals have continuity between them all.
Hope this made sense |
You will get continuity between all terminals, You have to do an ohm reading. common to run and common to start... ohms added together should equal the resistance between run to start, if that checks out your compressor is good.
__________________
2 to 4 inches in that range will be good
__________________
No, 2-4 inches is 1-2 lines below 0 on the 134 guage.Each line represents 2 inches. Any thing below zero is called inches of mercury. So when I refer to inches it means below zero. Anything above that would be an over charge. When you hook the guage to your running compressor, you should read about 27 to 28 inches. You can charge the system knowing this info.
__________________
| Display Modes | |
| Refrigerator handle replacement | Shirley Douglas | Refrigerator & Freezer Repair | 0 | 04-23-2008 05:36 PM |
| frig and freezer warm,clicking noisefrom compressor,compressor very hot | tdot | Refrigerator & Freezer Repair | 4 | 04-02-2008 09:35 AM |
| Refrigerator Compressor Problem | ptmoy | Refrigerator & Freezer Repair | 4 | 03-17-2008 04:31 PM |
| replacing a compressor in a refrigerator | Terry Kooienga | Refrigerator & Freezer Repair | 1 | 12-05-2007 04:23 PM |
| compressor replacement help | kcaaac | Refrigerator & Freezer Repair | 2 | 11-14-2007 06:22 PM |
