Discuss
how do I replace water line in freezer door of whirlpool side by side
 in
Refrigerator & Freezer Repair
Do you mean this cannot be repaired? The part is no longer available? Please expand Thank-you Ads By Google
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » how do I replace water line in freezer door of whirlpool side by side
  #31 (permalink)
Old 01-17-2013, 02:47 PM
Junior Member
mfdpa is on a distinguished road
Default Follow up question
Please expand
Thank-you
Ads By Google
  #32 (permalink)
Old 01-17-2013, 03:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
This part even does not have a part number. Looks like it was not serviceable by design.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #33 (permalink)
Old 02-18-2013, 03:02 PM
Junior Member
jacsac is on a distinguished road
Default Same whirlpool frig problem
Whirlpool gold model #GS6NVEXSL01 27 side by side
  #34 (permalink)
Old 02-18-2013, 05:19 PM
Junior Member
Default
Quote:
Not sure if you mean me et25dqrbw00 Whirlpool but the inside of the door is filled with a hard foam. I cut out the foam near where the water tube went in and found the 1/4" water tube inside a slightly larger plastic tube which I carefully cut into and pulled out a section of the 1/4" water tube an spliced in a piece of 1/4" water tubing using the connectors they sell here. It worked fine . I did not try to replace the small amount of foam I hacked out -seems to have no effect on temperature of fridge. There is a metal coil that the water tube has to go thru as it passes from the door to the fridge to keep the water tube from getting cut make sure that metal coil is secure inside the fridge door and passes thru the hole in the bottom of the door(duct tape).
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
side by side refrigerator - fridge side freezing food, water coming out of freezer bomb Refrigerator & Freezer Repair 8 08-30-2011 01:58 PM
Water dispenser line frozen in door-GE side/side JenniferL Refrigerator & Freezer Repair 0 09-27-2009 11:46 AM
Whirlpool Side-by-Side ice maker overfills, water runs over into freezer... threefivezero Refrigerator & Freezer Repair 1 07-06-2009 07:00 AM
Whirlpool side by side Ice maker spews water into freezer fraserm General Talk 3 12-06-2008 08:19 AM
ge side by side freezer door no ice/water/light wb7ccj Refrigerator & Freezer Repair 5 07-24-2008 02:30 PM
