Discuss
Upright freezer compressor relay burnt out
 in
Refrigerator & Freezer Repair
I need a new compressor starter relay - will the SUPCO kit work for me? The SUPCO specs say 1/12 -
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Upright freezer compressor relay burnt out
  #1 (permalink)
Old 05-27-2008, 05:44 PM
dmeyer4 dmeyer4 is offline
Junior Member
dmeyer4 is on a distinguished road
Default Upright freezer compressor relay burnt out
Model Number: EKV11CRW0   Brand: Whirlpool   Age: More than 10 years
I need a new compressor starter relay - will the SUPCO kit work for me? The SUPCO specs say 1/12 - 1/2 hp, and the compressor on this ancient RCA Whirlpool freezer has no identifying marks on it. I assume it's somewhere in that range - anyone have a guess as to whether that would work out for me?
Related Models
Whirlpool EL02CCXHW00
Whirlpool EL02CCXHW1
Whirlpool EL02CCXJW
Whirlpool EL02CCXLB
Whirlpool EL02CCXMB00 Refrigerator
Whirlpool EL02CCXMQ00 Refrigerator
Whirlpool EL02CCXPB00 Compact Refrigerator
Whirlpool EL02CCXPQ00 Compact Refrigerator
Whirlpool EL02CCXWW0
Whirlpool EL02PPXMB00 Refrigerator
Whirlpool EL02PPXMQ00 Refrigerator
Whirlpool EL03CCXDW00
Whirlpool EL03CCXFW00
Whirlpool EL03CCXHW00
Whirlpool EL03CCXJW
Whirlpool EL03CCXLB
Whirlpool EL03CCXMB00 Refrigerator
Whirlpool EL03CCXMQ00 Refrigerator
Whirlpool EL03CCXMS00 Refrigerator
Whirlpool EL03CCXRB00 Refrigerator
Whirlpool EL03CCXRQ00 Refrigerator
Whirlpool EL03CCXWW0
Whirlpool EL03PPXMB00 Refrigerator
Whirlpool EL03PPXML00 Refrigerator
Whirlpool EL03PPXMQ00 Refrigerator
Whirlpool EL05CCXAW0
Whirlpool EL05CCXDW00
Whirlpool EL05CCXFW00
Whirlpool EL05CCXHW00
Whirlpool EL05CCXJW
Whirlpool EL05CCXLB
Whirlpool EL05CCXLS
Whirlpool EL05CCXMB00 Refrigerator
Whirlpool EL05CCXMQ00 Refrigerator
Whirlpool EL05CCXMS00 Refrigerator
Whirlpool EL05CCXRB00 Refrigerator
Whirlpool EL05CCXRQ00 Refrigerator
Whirlpool EL05CCXRS00 Refrigerator
Whirlpool EL05CCXWW0
Whirlpool EL05PPXMB00 Refrigerator
Whirlpool EL05PPXML00 Refrigerator
Whirlpool EL05PPXMQ00 Refrigerator
Whirlpool EL11PCXMWR0
Whirlpool EL11PCXRWL0
Whirlpool EL11PCXRWR0
Whirlpool EL11SCLSW00
Whirlpool EL11SCRSW00
Whirlpool EL13PCXMWL0
Whirlpool EL13PCXMWR0
Whirlpool EL13PCXRWL0
Whirlpool EL13PCXRWR0
Whirlpool EL13SCLSW00
Whirlpool EL13SCRSW00
Whirlpool EL15CCXMWR0
Whirlpool EL15CCXMWR2
Whirlpool EL15CCXRWR0
Whirlpool EL15MNLSW00
Whirlpool EL15MNRSW00
Whirlpool EL15MNXMWR0
Whirlpool EL15MNXMWR1
Whirlpool EL15MNXRWR0
Whirlpool EL15SCLSW00
Whirlpool EL15SCRSW00
Whirlpool EL1WSRXLQ0 Refrigerator
Whirlpool EL2020WW0
Hardwick EL214-450 Mwave - Cntrtp / Stand Alone
Frigidaire EL27M6WAFA Gib(v1) / 27 " Laundry Center
Frigidaire EL27M6WAFB Gib(v1) / 27 " Laundry Center
Frigidaire EL27M6WXFA Gib(v1) / 27 " Laundry Center
Frigidaire EL27M6WXFB Gib(v1) / 27 " Laundry Center
Frigidaire EL27M6WXFC Gib(v1) / 27 " Laundry Center
Frigidaire EL27M6WXFD Gib(v1) / 27 " Laundry Center
Whirlpool EL3030WL1
Whirlpool EL3030WW0
Whirlpool EL3030WW1
Hardwick EL4-33A9 Surface Unit - Ele
Hardwick EL4-33B9 Surface Unit - Ele
Hardwick EL4-33S9 Surface Unit - Ele
Hardwick EL4-33W9 Surface Unit - Ele
Whirlpool EL4030VL0
Whirlpool EL4030VL1
Whirlpool EL4030VW0
Whirlpool EL4030VW1
Whirlpool EL5030VL0
Whirlpool EL5030VL1
Whirlpool EL5030VW0
Whirlpool EL5030VW1
Whirlpool EL5WTRXMB00 Refrigerator
Whirlpool EL5WTRXMQ00 Refrigerator
Whirlpool EL5WTRXMS00 Refrigerator
Whirlpool EL6050VL0
Whirlpool EL6050VW0
Whirlpool EL7ATRRKB00
Whirlpool EL7ATRRKB01
Whirlpool EL7ATRRKB02
Whirlpool EL7ATRRKQ00
Whirlpool EL7ATRRKQ01
Whirlpool EL7ATRRKQ02
Whirlpool EL7ATRRKS00
Whirlpool EL7ATRRKS01
Whirlpool EL7ATRRKS02
Whirlpool EL7ATRRMQ00 Refrigerator
Whirlpool EL7ATRRMQ01 Refrigerator
Whirlpool EL7ATRRMQ02 Refrigerator
Whirlpool EL7ATRRMQ03 Refrigerator
Whirlpool EL7ATRRMQ04 Refrigerator
Whirlpool EL7ATRRMQ05 Refrigerator
Whirlpool EL7ATRRMQ07 Refrigerator
Whirlpool EL7ATRRMQ08 Refrigerator
Whirlpool EL7ATRRMS00 Refrigerator
Whirlpool EL7ATRRMS01 Refrigerator
Whirlpool EL7ATRRMS02 Refrigerator
Whirlpool EL7ATRRMS03 Refrigerator
Whirlpool EL7ATRRMS04 Refrigerator
Whirlpool EL7ATRRMS05 Refrigerator
Whirlpool EL7ATRRMS07 Refrigerator
Whirlpool EL7ATRRMS08 Refrigerator
Whirlpool EL7JWKLMQ02 Refrigerator/freezer Convertible
Whirlpool EL7JWKLMS02 Refrigerator/freezer Convertible
Whirlpool EL87TRRRQ00 Refrigerator
  #2 (permalink)
Old 05-28-2008, 03:28 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Did you test the compressor as richappy advised: Upright freezer - compressor cycling, burnt smell?
If you did, what is the result?
__________________
  #3 (permalink)
Old 05-28-2008, 07:57 PM
Junior Member
Default
Gene, I finally figured out (correctly I hope) that you and Rich meant me to test the resistance between the 3 terminals on the compressor after disconnecting the roasted relay, to see if the compressor seemed electrically sound. Here are my results (the terminals and the wiring diagram on the back of the freezer refer to them as "C", "S", and "M" rather than C, S, and R. By process of elimination I guess that M goes to the run winding, and C=common, S=start.)
C-M: 3.1 ohms
C-S: 8.5 ohms
S-M: 11.3 ohms
I read up on compressor starter relays at e-refrigeration.com - Compressor Start relays and if I understand correctly, the start-run resistance should be equal to the sum of the common-start and common-run resistance readings. Is 11.3 close enough to 11.6 to pronounce it OK in my readings above?
  #4 (permalink)
Old 05-29-2008, 02:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
dmeyer4,
Looks like there is nothing wrong with the compressor motor but there is a possibility that are mechanical problems. I found the right OEM replacement for the start relay and I believe 35 bucks is worth a try.
- The part number for the relay and overload assembly is AP3119970
P.S. The part comes with the complete installation instructions.
__________________
  #5 (permalink)
Old 06-14-2008, 11:28 AM
Junior Member
Default Thanks Gene!
Fixed 'er up, sold it, made my money back and then some. Thanks for the advice!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Possible compressor relay problem Pottspd Refrigerator & Freezer Repair 4 10-14-2008 09:36 PM
Upright freezer - compressor cycling, burnt smell dmeyer4 Refrigerator & Freezer Repair 4 05-28-2008 05:11 PM
Frig compressor/relay capacitor Mkendall Refrigerator & Freezer Repair 3 03-12-2008 02:31 PM
Upright Freezer Compressor does not kick on Kaye Refrigerator & Freezer Repair 7 01-15-2008 10:43 AM
Compressor Relay Arrangement ISAACADKINS Refrigerator & Freezer Repair 2 09-11-2007 03:12 PM
