my icemaker is not getting water, but my water dispenser works fine. The line does not appear to be clogged and I was wondering if it could be a faulty filter valve assembly. Or is it possible that the water filter that should be replaced every 6 mos is clogged? Could this stop water from flowing to the icemaker but not the water dispenser? I was also wondering if the wire shutoff arm could have a faulty switch that allows it to be in the on position (arm down) but is broken? Any help would be greatly appreciated. Michelle
