| » Refrigerator not cooling, but freezer is working |
Quote:
My fridge is warm but my freezer is fine. I have been reading this but trying to grasp it all (I know nothing about this kind of stuff) Do I empty out the freezer and pull out a wall or pull out the whole fridge/freezer and pull off a wall there to check the coils? I have a Frigidaire model FRS26WRC TIA!! |
The first thing I would do is remove all food from the freezer and check for the snow on the back panel.
If there is a snow, then the problem is with the defrost system. If there is no snow, then check if the fan in the freezer is running. Please, post your findings. - Here are the break down diagrams for the Frigidaire refrigerator Model FRS26WRCD0 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
There is definately a "Snow" build up on the back panel. So is it worth having a repair person out to fix (I have no idea what the costs would be?) or should we just get a new fridge? I don't want to spend $400+ fixing an old fridge when that's almost 1/2 the price of a new one.
Looks like the problem is a faulty defrost system.
It consists of three parts: defrost timer (#23 on the controls break down diagram), defrost heater (#14 on the system break down diagram) and the defrost thermostat (#21 on the system break down diagram). Locate the pin in the center of the defrost timer (through the hole in the cover) and, using a flat screwdriver, slowly turn it clockwise until it clicks. Wait about 10 minutes and check if the defrost heater got hot (the coils behind the back panel in the freezer should be covered with snow). If the defrost heater got hot, then replace the defrost timer. If not, then unplug the fridge and check the defrost heater for continuity. If the defrost heater is open, replace it. If the defrost heater is closed, then replace the defrost thermostat. - The part number for the defrost timer AP2111929 - The part number for the defrost heater AP2593107 - The part number for the defrost thermostat AP2150024 The cost of repair in the worst case (if the problem is a bad defrost heater) is going to be a little bit over a $100. Gene.
__________________
I see alot of people with a similar problem, but not sure if it is the same. My freezer did get warm and started defrosting items, and we notice the frig was getting warm. We removed items from the freezer and now it seems to be working some what. The frig is at 57 degrees and last night the freezer was at 21 but the stuff on the door is slightly defrosted. I don't hear the frig kick in when the door is open too long. A friend thought it may be the compressor. Any thoughts
In order to give the most accurate advise I need the complete model number of the fridge.
Post it as a new thread, please. Gene.
__________________
Quote:
Last edited by appliance tech : 12-27-2007 at 11:15 PM. Reason: add info: you may have ice in ducts to the refrigerator part |
SUSHIDAN,
What is the complete model number of the refrigerator? Is there any frost on the back panel in the freezer? Gene.
__________________
| Display Modes | |
| Refrigerator/freezer problems | imthewraith | Refrigerator & Freezer Repair | 3 | 09-17-2007 03:28 PM |
| Refrigerator/Freezer | Caroline42 | Refrigerator & Freezer Repair | 1 | 07-20-2007 05:57 PM |
