Discuss
Refrigerator not cooling properly
 in
Refrigerator & Freezer Repair
I have a Maytag side by side refrigerator that is not cooling properly. I measured 45 def F with an
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator not cooling properly
  #1 (permalink)
Old 05-27-2008, 10:19 AM
kjr56 kjr56 is offline
Junior Member
kjr56 is on a distinguished road
Default Refrigerator not cooling properly
Model Number: msd2756gew   Brand: Maytag   Age: 5 - 10 years
I have a Maytag side by side refrigerator that is not cooling properly. I measured 45 def F with an HVAC thermomiter with the control turned all the way up. The freezer is freezing and it is making ice properly. The Freezer control is set at about 5.5 out of 9. I measured 6 deg in the freezer. I cleaned the condenser and checked the evaporator coil for freezing. There was none , so it appears like it is defrosting. The only other possibilities I see is the cooling control or something wrong with the compressor or freon. Any ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-27-2008, 08:58 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Check if the cold air is coming through the damper and you are available to adjust the air flow with the "Refrigerator temperature" lever.
Here are the break down diagrams for the Maytag refrigerator Model MSD2756GEW
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
refrigerator not cooling or freezing properly. Bill K Refrigerator & Freezer Repair 4 08-09-2008 10:06 AM
GE refrigerator not cooling mlafoy Refrigerator & Freezer Repair 0 02-24-2008 01:35 PM
Regrigerator section not cooling properly billchamp Refrigerator & Freezer Repair 1 12-03-2007 04:44 PM
fresh foods section not cooling properly andylitam Refrigerator & Freezer Repair 0 08-22-2007 07:37 AM
Refer side not cooling properly, freezer okay lynbo11 Refrigerator & Freezer Repair 0 07-30-2007 08:02 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
