Water started running out of the refrigerator through the ice maker and so I turned off the water to the refrigerator. I replaced the ice maker with part number WR30X10093 yesterday but it isn't making ice. No water is going into the ice tray. However I can get water from the front of the refrigerator for drinking. Is there something else wrong? Is there another part that controls water flow to the ice tray?
There is a strong possibilit that the original problem was the dual water valve, AP3672839 not the ice maker. You might check it on the ice maker side for continuity at the valve.
