The Refrigeator Had A Light Bulb Out. I Replaced It With The Same Bulb. When I Did All Of The Refrigeator Side Lights Went Out. Please, I Can Use Your Help.
Sounds like the wiring harness or one of the connections at the light socket came loose. Click on your model # and go to liner parts so you can see how it comes apart. Make sure you turn off then uplug the refrigerator first.
Good Luck
