GE refr Model No PDS22MHRBBB I recieved a new evap motor every thing looks the same but the electical plug is completly different. I called and they say it's the right motor What do I do Gary
Note that I do not work for AppliancPartsPros so cannot look up any info for you. Here are your parts Replacement parts for General Electric PDS22MHRBBB Refrigerator | AppliancePartsPros.comIf you click on the picture of the parts a new page will open with more views perhaps you will be able to tell if you actually did get the correct part. You may have an Condenser fan Item 812 in Section 2 instead of an evaporator fan Item 610 in Section 2. |
THIS FORUM IS DEAD!!!!!!! |
