Hi to the Fridge Experts... Water is draining into fridge... Fridge/Freezer is working fine... Freezer is set to "O" deg and Fridge is set to just below "40" deg... Doors seal properly, doors close on their own, fridge is leveled properly... Drain pan under fridge is bone dry... Drain tubes not clogged at drain pan end...
I am a retired Heavy Equip. Field Mechanic on a fixed income... Honestly can't afford to call a repair person to fix... I have many years experience in automotive a/c and heating... If the a/c was leaking water into the the vehicle, i would know right where to go to unclog and fix... Would one of you Fridge experts kindly lead and guide me to the possible clog and how to get to it, for this particular model...
Thanks in advance... CyBoz...
