From time to time the pump gets hung up and agitates makinga steady intermitent noise(vroom, vroom, vroom), sounds sort of like a dishwasher and is not recirculating water over thr coil. When I turn the unit off and then back on it resets and works fine, but this is starting to happen more often. Is this a brain (pc board) problem?
Is the source water filtered?
No. Ther is no filter. Are you thinking trash in the water valve?
Yes. If so, try to clean it out, but be careful not to damage the screen. Here's areplacement part number: Part number: AP3891150
Thanks. I will do just that and install in line filter.
