freezer not freezing staying around 38 to 40+ degrees, replaced seal, dosen't sound as if compresor is coming on
Look into the freezer and see if there is a snowy frost build-up. This would indicate a defrost problem. Given the age of the refrigerator, though, I would hazard a guess thet you have a refrigerant leak.
