rjp
#1 Posted : Monday, March 8, 2010 7:30:19 AM(UTC)
rjp
Cleaned coils 2-3 weeks ago when it first stopped cooling...very dirty..never were cleaned before. Plugged it back in after being off over night and started cooling again right away. Now 3 weeks later fridge and freezer stopped cooling again. Just unplugged it again over night and it is working again. Any ideas on where to start to look for this problem.
Thanks for your help.
rjp
#2 Posted : Wednesday, March 10, 2010 8:01:00 PM(UTC)
rjp
bump...need a little help please
#3 Posted : Thursday, March 11, 2010 1:19:56 AM(UTC)
I would pull he motherboard out behind the fridg and look for bad solder joints in the back around the power relay. If ok, I would replace the board and the refigerator thermisters. Board # AP4436216, thermisters(a white, thin plastic part) AP3185407
funtime24
#4 Posted : Thursday, March 11, 2010 9:51:42 AM(UTC)
funtime24
Is the Evaporator Coil in the back of the freezer freezing up? (does it have about a 1/2 inch of frost and ice?) This may be a problem with your refrigerators Defrost Cycle and would be far less expensive to repair!
#5 Posted : Thursday, March 11, 2010 3:31:06 PM(UTC)
Pull the 3 pin power connector(gray plug) off the motherboard, notice which pins on the connector mate with the pc board line and def. pins. Stick a jumper between these pins and see if it now defrosts. If so, you have a bad motherboard. If not, you probably have a blown defrost heater.
rjp
#6 Posted : Sunday, March 21, 2010 7:20:52 PM(UTC)
rjp
There is a definite burnt solder joint on the back of the mother board...what now? replace it?"
#7 Posted : Monday, March 22, 2010 1:17:41 AM(UTC)
Just resolder it or take it to a shop to have it done.
rjp
#8 Posted : Monday, March 22, 2010 6:41:56 AM(UTC)
rjp
No problem...I can do that...but what could have caused it to burn and whats to stop it from doing it again. Just curious and thanks again for the help.
whirlpool fridge/freezer not cooling to proper temperature (Refrigerator & Freezer Repair)
by stephenb489 9/11/2014 6:23:22 AM(UTC)
Fridge/Freezer not cooling. (Refrigerator & Freezer Repair)
by todd2371 4/29/2014 5:12:09 AM(UTC)
Frigidaire fridge/freezer not cooling and fan issues (Refrigerator & Freezer Repair)
by Eric Z 3/7/2014 1:09:54 PM(UTC)
Apartment mini-fridge/freezer not cooling (Refrigerator & Freezer Repair)
by cougartrace 4/10/2013 3:47:37 AM(UTC)
Amana fridge/freezer not cooling (Refrigerator & Freezer Repair)
by calumnicol 8/21/2012 4:04:38 AM(UTC)
Another Fridge/Freezer not cooling (Refrigerator & Freezer Repair)
by carjeff 4/30/2012 7:32:40 AM(UTC)
GE side by side fridge/freezer not cooling or freezing (Refrigerator & Freezer Repair)
by Lou7 4/23/2012 8:36:19 PM(UTC)
Fridge/Freezer not cooling evenly (Refrigerator & Freezer Repair)
by DaneKast 10/14/2011 8:55:25 AM(UTC)
Fridge/freezer not cooling properly (Refrigerator & Freezer Repair)
by chouseal 7/23/2011 9:42:13 AM(UTC)
Kitchenaid Fridge/freezer not cooling (Refrigerator & Freezer Repair)
by robnuss 7/8/2011 11:42:24 PM(UTC)
Fridge/Freezer Not Cooling, Compressor Hot (Refrigerator & Freezer Repair)
by ryanej 4/20/2011 5:40:52 PM(UTC)
GE Fridge/Freezer Not Cooling Freezer Properly (Refrigerator & Freezer Repair)
by woody1397 2/2/2011 2:27:18 PM(UTC)
Fridge/freezer not cooling GE model # gts18jcparww (Refrigerator & Freezer Repair)
by timdogg 12/22/2010 7:02:09 PM(UTC)
by Peekin 12/6/2010 8:47:47 AM(UTC)
by cassiopia89 11/21/2010 11:51:59 PM(UTC)
