Discuss
Replace adaptive defrost board with 8hr timer?
 in
Refrigerator & Freezer Repair
Hi All, Thanks to all the great hints on this forum, it appears that I have a bad adaptive defrost
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Replace adaptive defrost board with 8hr timer?
  #1 (permalink)
Old 03-06-2010, 10:01 PM
Junior Member
gleyh is on a distinguished road
Default Replace adaptive defrost board with 8hr timer?
Model Number: MZD2766   Brand: Maytag   Age: 5 - 10 years
Hi All,
Thanks to all the great hints on this forum, it appears that I have a bad adaptive defrost board. Multiple experts mention that these boards are problematic. Further, I can't seem to find a exact replacement for my board [all the ones I've seen are mounted in a small white plastic case, my board is a stand-alone unit.]
However, I see that multiple mechanical 8hr timers are available. They appear to mechanically fit exactly where the ADB goes; there's even a hole for the rotating shaft in my existing molding. My question: Can I retrofit my fridge with an 8hr mech timer? Would seem to be a more reliable solution. Has anyone done this? -Greg
27 Mar 10 Update -- I went with the 8hr mech timer upgrade, since it was available from appliancepartspros.com for $17, 3-day delivery. I did check out availability of an improved $66 ADB board here { Adaptive Defrost Controls - Capable Controls } but delivery time through the complex distributor chain [3 distrib and 1 wholesaler!] was over two weeks... no stock in the San Francisco area! The new mech timer fit exactly where the old ADB board went, and came with two mounting screws. I wired the timer according to the diagrams in the manual provided by Denman, below. Added four crimp-on spade lugs to adapt the existing wires. One of the five wires wasn't required for the mech timer, so I capped it off.
After two weeks the timer still works great, no noticeable ice buildup.
Related Models
Maytag MZD2766GEB REF - SXS/I&W
Maytag MZD2766GEQ REF - SXS/I&W
Maytag MZD2766GES REF - SXS/I&W
Maytag MZD2766GEW REF - SXS/I&W
Maytag MZD2768GEB REF - SXS/I&W
Maytag MZD2768GEQ REF - SXS/I&W
Maytag MZD2768GEW REF - SXS/I&W
Whirlpool N N ELECTRIC RANGES AND OVENS
Norge N1100PAW RANGE- F/S STD GAS
Norge N1100PRA RANGE- F/S STD GAS
Norge N1100PRA-L RANGE-F/S CONT CLEAN GAS
Norge N1100PRW RANGE- F/S STD GAS
Norge N1100PRW-L RANGE-F/S CONT CLEAN GAS
Norge N1500PRA RANGE- F/S STD ELE
Norge N1500PRW RANGE- F/S STD ELE
Norge N31100PAA RANGE- F/S STD GAS
Norge N31100PAW RANGE- F/S STD GAS
Norge N3110KRA RANGE- F/S STD GAS
Norge N3110KRW RANGE- F/S STD GAS
Norge N3110PPA RANGE- F/S STD GAS
Norge N3110PPW RANGE- F/S STD GAS
Norge N3110PRA RANGE- F/S STD GAS
Norge N3110PRW RANGE- F/S STD GAS
Norge N31111XAA RANGE- F/S STD GAS
Norge N31111XAW RANGE- F/S STD GAS
Norge N31115WAV RANGE- F/S STD GAS
Norge N31115XAA RANGE- F/S STD GAS
Norge N31115XAW RANGE- F/S STD GAS
Norge N3120SPA RANGE- F/S STD GAS
Norge N3120SPN RANGE- F/S STD GAS
Norge N3120SPW RANGE- F/S STD GAS
Norge N3120SRA RANGE- F/S STD GAS
Norge N3120SRW RANGE- F/S STD GAS
Norge N3121XPA RANGE- F/S STD GAS
Norge N3121XPW RANGE- F/S STD GAS
Norge N3121XRA RANGE- F/S STD GAS
Norge N3121XRW RANGE- F/S STD GAS
Norge N3121XTA RANGE- F/S STD GAS
Norge N3121XTW RANGE- F/S STD GAS
Norge N3137XRA RANGE- F/S STD GAS
Norge N3137XRW RANGE- F/S STD GAS
Roper N3157*0 Ranges, Electric*
Roper N3157*1 Ranges, Electric*
Roper N3157W0 Ranges, Electric*
Roper N3157W1 Ranges, Electric*
Norge N3177VUV RANGE- F/S STD GAS
Norge N3177XRA RANGE- F/S STD GAS
Norge N3177XRW RANGE- F/S STD GAS
Norge N3177XUA RANGE- F/S STD GAS
Norge N3177XUW RANGE- F/S STD GAS
Roper N3257*0 Ranges, Electric*
Roper N3257*1 Ranges, Electric*
Roper N3257W0 Ranges, Electric*
Roper N3257W1 Ranges, Electric*
Roper N3357*0 Ranges, Electric*
Roper N3357W0 Ranges, Electric*
Norge N3422PRA RANGE- S/C F/S GAS
Norge N3422PRW RANGE- S/C F/S GAS
Norge N3438SRA RANGE- S/C F/S GAS
Norge N3438SRW RANGE- S/C F/S GAS
Norge N3438VRV RANGE- S/C F/S GAS
Roper N3457*0 Ranges, Electric*
Roper N3457W0 Ranges, Electric*
Norge N3472SRA RANGE- S/C F/S GAS
Norge N3472SRW RANGE- S/C F/S GAS
Norge N3478VRV RANGE- S/C F/S GAS
Norge N3478VVV RANGE- S/C F/S GAS
Norge N3478XRA RANGE- S/C F/S GAS
Norge N3478XRW RANGE- S/C F/S GAS
Norge N3478XVA RANGE- S/C F/S GAS
Norge N3478XVW RANGE- S/C F/S GAS
Norge N3510KRA RANGE- F/S STD ELE
Norge N3510KRW RANGE- F/S STD ELE
Norge N3510PPA RANGE- F/S STD ELE
Norge N3510PPW RANGE- F/S STD ELE
Norge N3510PRA RANGE- F/S STD ELE
Norge N3510PRW RANGE- F/S STD ELE
Norge N3520SPA RANGE- F/S STD ELE
Norge N3520SPN RANGE- F/S STD ELE
Norge N3520SPW RANGE- F/S STD ELE
Norge N3520SRA RANGE- F/S STD ELE
Norge N3520SRW RANGE- F/S STD ELE
Norge N3521XPA RANGE- F/S STD ELE
Norge N3521XPW RANGE- F/S STD ELE
Norge N3521XRA RANGE- F/S STD ELE
Norge N3521XRW RANGE- F/S STD ELE
Norge N3832XRA RANGE- S/C F/S ELE
Norge N3832XRW RANGE- S/C F/S ELE
Norge N3875XRA RANGE- S/C F/S ELE
Norge N3875XRW RANGE- S/C F/S ELE
Norge N3878VRV RANGE- S/C F/S ELE
Norge N3878VVD RANGE- S/C F/S ELE
Norge N3878VVV RANGE- S/C F/S ELE
Norge N3878XRA RANGE- S/C F/S ELE
Norge N3878XRW RANGE- S/C F/S ELE
Norge N3878XVA RANGE- S/C F/S ELE
Norge N3878XVW RANGE- S/C F/S ELE
Magic Chef N40C-3-X9 MWAVE- CNTRTP / STAND ALONE
Norge N4231WRA RANGE-F/S CONT CLEAN GAS
Norge N4231WRW RANGE-F/S CONT CLEAN GAS
Norge N4251WTA RANGE- F/S STD GAS
Norge N4251WTW RANGE- F/S STD GAS
Roper N9157*0 Ranges, Electric*
Roper N9157*1 Ranges, Electric*
Roper N9157L0 Ranges, Electric*
Roper N9157L1 Ranges, Electric*
Roper N9157X0 Ranges, Electric*
Roper N9257*0 Ranges, Electric*
Roper N9257*1 Ranges, Electric*
Roper N9257*2 Ranges, Electric*
Roper N9257L1 Ranges, Electric*
Roper N9257L2 Ranges, Electric*
Roper N9257X0 Ranges, Electric*
Roper N9257X1 Ranges, Electric*
Roper N9357*0 Ranges, Electric*
Roper N9357*2 ELECTRIC RANGE
Roper N9357*3 Ranges, Electric*
Roper N9357L0 Ranges, Electric*
Roper N9357L2 ELECTRIC RANGE
Roper N9357L3 Ranges, Electric*
  #2 (permalink)
Old 03-06-2010, 10:39 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
If the wiring connector is identical, I would say yes.
  #3 (permalink)
Old 03-06-2010, 11:16 PM
Junior Member
Default
Quote:
The connectors are different, but shouldn't the functionality be the same? I'm assuming that I'll have to re-crimp some spade lugs to adapt to the 8hr timer.
  #4 (permalink)
Old 03-07-2010, 04:31 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here is the manual for these unit which should help
http://www.servicematters.com/maytag...s/16010154.pdf
A timer will probably cost you more in energy since it does not vary the defrost cycle frequency.
You list your unit 5 to 10 years old so if this is the first one you have replaced I personally would replace it with an adaptive board.
If you do decide to go the timer route you could use another model number from the manual to find a timer that will fit properly.
__________________
  #5 (permalink)
Old 03-07-2010, 04:39 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Adaptive defrost boards blow out from power surges.
To prevent this, I would add a 1000 Joule surge protector to the wall outlet.
These are available at Lowe's and you must select one designed for refrigerators. Comes in a blue box, $12.95
__________________
  #6 (permalink)
Old 03-07-2010, 12:01 PM
Junior Member
Default
Awesome, thanks for the manual. I had googled everywhere for that!
Guess I'm a bit miffed seeing they use a PIC microcontroller on the ADB. I have some experience with PICs. Like any uC they can latch up, requiring a power-off reset. This is not a technology I would have chosen to replace a simpler, more reliable mechanical timer. Also, the mech timer appears to have 15A contacts where the ADB relay is rated at 10A.
The marginal power savings of an ADB even over several years is easily wiped out by me having to spend a weekend tearing the fridge apart, and buying replacement components.
From the manual it looks like the mech timer upgrade is relatively straightforward. I have some crimp lugs for it.
  #7 (permalink)
Old 03-07-2010, 06:55 PM
Senior Expert
APP Volunteer
Default
Always good advise. Also check with your local electrician: In my area a typical (1800-2200 sq ft) house can be "Whole House" surge protected for around $200. A fantastic deal, considering that an electric range, electric dryer, and an electric water heater are otherwise hard to protect.
  #8 (permalink)
Old 03-08-2010, 03:09 AM
Senior Expert
APP Volunteer
Default
A mechanical defrost timer draws about 300 watts for about 40 minutes in 24 hours. A adaptive defrost timer will make this time less as a function of door openings and other factors. In the end, you will probably save $2-4 a month with the adaptive defrost, which is rather small.These figures are just a rough estimate.
Thus, considering everything with this particular case, I would use the mechanical defrost timer.
If anyone has better/more accurate data, please jump in.
__________________
  #9 (permalink)
Old 09-13-2017, 05:16 AM
Junior Member
alwaysaffordableappliance is on a distinguished road
Default
Quote:
Originally Posted by gleyh View Post
Hi All,
Hi I am interested in doing this same thing, however I do not see any manual below. Can you help by any chance? I just need to know the wiring configuration, I have blade terminals and defrost timers. Thanks! J
James
  #10 (permalink)
Old 09-13-2017, 06:42 AM
Senior Expert
APP Volunteer
Default
Below is a link to an alternate source for the manual I provided to gleyh for a Model MZD2766
https://drive.google.com/drive/folde...EhtV0YxUTRrbTA
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Does my Maytag have a defrost timer or adaptive defrost control? Where is it? Momto8 Refrigerator & Freezer Repair 13 06-18-2012 07:37 PM
How to replace adaptive defrost board dj okay Refrigerator & Freezer Repair 1 02-28-2011 08:09 AM
freezer icing up - which circ. board contains the defrost timer? frankv Refrigerator & Freezer Repair 5 08-27-2010 05:07 PM
Adaptive defrost board installation wrmixon Refrigerator & Freezer Repair 1 08-07-2009 06:41 PM
Should I replace both defrost heaters? Timer Location? MichiganLarry Refrigerator & Freezer Repair 7 06-05-2008 11:06 PM
