Yesterday while opening my fridge the entire door came off in my hand! I was able to balance it temporarily back on the bottom hinge where it pivots. What replacement part do I need? A door closer kit? Or a Cam Assembly kit? Fridge still works great....just gotta keep the door on. :p Is this an easy part to install myself? Thanks
Rank:: Advanced Member
THIS FORUM IS DEAD!!!!!!! |
OK...bottom right corner of the fridge door when it is closed. There are two black grooved circles that fit on top of each other and rotate as the door opens and closes. One appears to be attached to the door itself while the other was attached to the support hinge. The bottom black circle appears to have broken off the support hinge and the pivot pin that fits thru the center of the two black circles falls out so as you open the door. The door slides off the support hinge as you open the door cause there is nothing to hold the black thingy in place
Check out Item 451 in Section 4. Click on it's picture to get better views |
