| » Deciphering icemaker LED lights |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: GS6HEXMO00 Brand: Whirlpool Age: 1 - 5 years
The LED lights on the icemaker double blink red when the flapper door on the left is open and blocking the path and is solid red when the door is pushed in opening the path.
The icemaker quit cycling and making ice a couple of weeks ago. I would certainly appreciate any help in futher diagnosing the problem. Thank you. |
Remove the ice maker and check the water feeding tube for ice inside.
Remove the front cover from the ice maker and check for 120VAC between the "L" and the "N" test points. Make sure both test leads of the meter go into the test points 1/2". If there is no 120VAC check the plug connection. Remove the plug and check the thermal fuse which is spliced into the black wire of the ice maker wire harness. If there is no continuity the ice maker has to be replaced. If the fuse is fine check the wire harness at the bottom (on some models at the top) of the freezer door. If there is 120VAC across the "L" and the "N" test points short the "T" and the "H" test points with an insulated piece of wire (14 GA) to run the motor. If the motor does not run replace the ice maker. If the motor runs, leave the jumper in for a half of a revolution to see if the heater under the ice maker mold heat up. If not - replace the ice maker. Remove the jumper and the water valve should be energized in the last half of the revolution. - The part number for the ice maker is AP3182733 Here are the break down diagrams for the Whirlpool refrigerator Model GS6SHEXMQ00 Gene.
__________________
Professional appliance repair services in Orange County, California. |
| Display Modes | |
| Nothing Happens, All Lights flash | Survivor | Washer Repair | 5 | 06-23-2008 07:10 PM |
| no lights or fan on ge profile | wayneo | Microwave Repair | 1 | 12-25-2007 05:34 PM |
| no lights | Andyindra | Refrigerator & Freezer Repair | 1 | 12-17-2007 06:41 PM |
| Lights do not turn on | dgulbin@optonline.net | Microwave Repair | 1 | 10-13-2007 02:29 AM |
| Working, but no lights | geckomon | Refrigerator & Freezer Repair | 2 | 09-11-2007 08:16 AM |
