Discuss
refrigerator/freezer repair
 in
Refrigerator & Freezer Repair
compresser runs all the time frig is warm and freezer doesn't freeze. I put in a new defrost timer
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » refrigerator/freezer repair
  #1 (permalink)
Old 05-20-2008, 05:29 PM
tinycat tinycat is offline
Junior Member
tinycat is on a distinguished road
Default refrigerator/freezer repair
Model Number: 253   Brand: Frigidaire   Age: 5 - 10 years
compresser runs all the time frig is warm and freezer doesn't freeze. I put in a new defrost timer thinking that would solve problem but it did not. because freezer had build of frost on back wall. please help if you know of what else I can do. thanks bbounds
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-20-2008, 05:50 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Pull the freezer back panel out and check frost pattern, if all frosted over, defrost with hair dryer and replace the little round defrost thermostat clipped to the evaporator coil. Before replacing the thermostat, temporarily short it's leads and turn the defrost timer to defrost, heater should heat up. If not, replace it also.
Post results.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Freezer door repair ajd Refrigerator & Freezer Repair 3 03-15-2008 11:31 AM
Refrigerator/Freezer has liquid leaking inside freezer and frig terrib Refrigerator & Freezer Repair 0 12-25-2007 11:15 PM
Refrigerator Freezer repair Marcelchris Refrigerator & Freezer Repair 1 12-03-2007 10:29 AM
Freezer door repair deevalerie Refrigerator & Freezer Repair 1 07-26-2007 05:30 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
