Discuss
Water valve assy
 in
Refrigerator & Freezer Repair
I received part WR57X10012 but instead of having push disconects for the output valves it has threaded connectors I need
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water valve assy
  #1 (permalink)
Old 05-19-2008, 03:20 PM
George Handte George Handte is offline
Junior Member
George Handte is on a distinguished road
Default Water valve assy
Model Number: TFX20JR   Brand: GE   Age: 1 - 5 years
I received part WR57X10012 but instead of having push disconects for the output valves it has threaded connectors I need the nuts for these. one is for a 1/4 inch plastic line the other is for a 3/16 plastic line. Your picture of the part shows it with the the push disconnects. I talked to your salesman but he couldn't help. Do you know where I can get the compression nuts for this fitting
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-20-2008, 03:14 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
My book shows compression fittings. You can buy these at Lowe's. This valve is better than the quick disconnect type as you can always replace the lines if they go bad.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Water Valve txjames101@yahoo.com Refrigerator & Freezer Repair 3 09-13-2008 04:37 PM
Ice Maker water valve Jaye Refrigerator & Freezer Repair 1 12-11-2007 06:26 PM
Wires to water valve? eva224 Dishwasher Repair 0 11-26-2007 11:37 AM
Maytag has new water valve, but no water ultimatefighter34 Dishwasher Repair 3 11-02-2007 01:02 PM
Water inlet valve m/c Refrigerator & Freezer Repair 2 07-31-2007 11:34 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
