Discuss
Defrost Cycle Problem
 in
Refrigerator & Freezer Repair
The refrigerator stated to warm up then the freezer. We puller all items. We also removed the evaporator cover in
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Defrost Cycle Problem
  #1 (permalink)
Old 05-19-2008, 12:58 PM
mr69camaro mr69camaro is offline
Junior Member
mr69camaro is on a distinguished road
Default Defrost Cycle Problem
Model Number: sxd26vl   Brand: Amana   Age: 1 - 5 years
The refrigerator stated to warm up then the freezer. We puller all items. We also removed the evaporator cover in the freezer. We noticed that everything was all froze up. We defrosted in w/ hair dryer. Then we let it run for a couple weeks. It started to freeze up again. I then knew it had to do w/ the defrost cycle. I turned the timer till it clicked and went into defrost mode and waited nothing happened. So I then unplugged the refrigerator and bypassed the defrost thermostat. Then plugged it in and the heater started and completed the defrost cycle. Then the compressor turned back on but the fan would not start. I unplugged the refrigerator and plugged back in the defrost thermostat and then plugged the refrigerator back in and the fan turned on and everything works fine.
Someone is trying to tell me my compressor is bad and to buy a new refrigerator, but I think all I need is a new defrost thermostat.
Please advise
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-19-2008, 01:34 PM
glen65 glen65 is offline
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
Does the entire evaporator frost over like in the
picture below?
  #3 (permalink)
Old 05-19-2008, 02:42 PM
Junior Member
Default
The first time it was not that bad, we defrosted it with hair dryer then it ran for a few weeks before it seamed to get pretty frosty. I think the thermostat is telling the heater not to turn on. I can force it into defrost cycle w/ the clock and bypassing the thermostat.
I am just worried about replacing defrost thermostat part and then having a compressor problem.
  #4 (permalink)
Old 05-19-2008, 03:01 PM
kooler kooler is offline
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default go4it
Your problem description certainly points at the defrost termination thermostat as the culprit... By all means replace it; if the evaporator coil is icing completely in a week or two then your compressor is doing what it's supposed to do... Sounds like it'll be just fine to me... cheers
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana frig Freezer defrost problem ct2023 Refrigerator & Freezer Repair 1 04-09-2008 01:46 PM
whirlpool refrigrerator defrost problem cookdd Refrigerator & Freezer Repair 1 08-02-2007 06:49 PM
defrost cycle problem blessen Refrigerator & Freezer Repair 2 07-29-2007 11:31 AM
GE Top frz defrost problem? vrocrider Refrigerator & Freezer Repair 1 07-21-2007 11:40 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
