Discuss
Install freezer gasget on door
 in
Refrigerator & Freezer Repair
Does installation require adhesive? If so, what kind. How do I remove old gasget?
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Install freezer gasget on door
  #1 (permalink)
Old 08-29-2007, 03:36 PM
Keith Nightingale Keith Nightingale is offline
Junior Member
Keith Nightingale is on a distinguished road
Default Install freezer gasget on door
Model Number: BX22A2L   Brand: Amana   Age: 5 - 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-30-2007, 02:22 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Hi Keith,
No adhesive required. The gasket goes inbetween the inner and outer door panels.
Before replacing the gasket, soak the new gasket in warm water for an hour or two, then dry it with a towel.
Open the door, remove door bins, then starting from the top replace the door gasket in sections. Mentally divide the door in quarters. Remove the old gasket from the upper 1/4 and install the new gasket in place. Then the 2nd 1/4, etc. This will help keep the door panels even.
Keep in mind that you have to give it about 24 hours for the new gasket to take shape. After 24 hours, do the dollar test to make sure it's sealing correctly.
Dollar test: very simple. Slide the dollar bill inbetween the door and the cabinet, close the door and pull on the dollar. If you feel resistance, it's fine. Do this about every 6 inches all around the door. If you come to a spot where you don't feel any pull on the dollar bill, try adjusting the gasket.
Hope this helps.
  #3 (permalink)
Old 08-31-2007, 03:32 PM
Junior Member
Default
Thanks so much for the clear instructions! You make me want to come back in the future.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
install condenser coils pattraveler Refrigerator & Freezer Repair 0 08-28-2007 12:28 PM
Freezer door not sealing RadRick Refrigerator & Freezer Repair 1 08-08-2007 06:49 PM
bOOT RE-INSTALL m1964 Washer Repair 0 08-05-2007 06:36 AM
Freezer door repair deevalerie Refrigerator & Freezer Repair 1 07-26-2007 05:30 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
