Discuss
ICe maker works- no ice dispensed
 in
Refrigerator & Freezer Repair
I am having the same problem as below exactly: but I didnt see any help post. How do I proceed?
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » ICe maker works- no ice dispensed
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-16-2008, 09:45 AM
pluey pluey is offline
Junior Member
pluey is on a distinguished road
Default ICe maker works- no ice dispensed
Model Number: GSH25JSRF SS   Brand: GE   Age: 1 - 5 years
I am having the same problem as below exactly: but I didnt see any help post. How do I proceed? thanks,
I have a GE refrigerator: model # Gsh25jsrf ss
I have trouble with the ice/water dispenser. The ice maker works fine and appears to make ice in the ice tray. But when I press the dispenser for ice, it doesn't dispense any. Further, I don't hear any mechanical sound indicating that it is even trying. The water dispenser dispenses water some times and doesn't at other times. It is very erratic.
Here's the troubleshooting that I have done:
1. I have disconnected the water filter and have now routed the pipe to the dispenser straight from the dual dispenser valve at the back of the refrigerator. In other words, I have disabled the flow of water via the filter and connected it so that it goes straight to the dispenser.
2. I went to the dual valve dispenser at the back of the refigerator to see if there's an electrical current at the line when the dispenser is pressed. During the times that the water dispenser wasn't working, I didn't pick up an electrical current but at times when the water dispenser was working, the current came through.
3. I have not tried to remove the trim yet.
4. I have also tried to keep the thermostat inside the refrigerator and freezer on the warm side hoping to unclog any inline freezes
What do you think is the issue ? Do you think that the dual valve is not functioning properly ? Or do you think that some electrical controls behind the dispenser trim might have to be replaced ? Particularly given that the ice maker seems to make ice without any issues and atleast some of the time, the water dispenser is able to dispense the water ?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-16-2008, 07:09 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Check the wire harness under the freezer door. If there is nothing wrong then the problem is a bad main control board.
- The part number for the main control board is AP3950129
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice maker works. Won't dispense cubes or crushed ice Derjimmer Refrigerator & Freezer Repair 32 08-11-2008 11:36 AM
ice maker works water indoor does not johnadam Refrigerator & Freezer Repair 1 04-08-2008 03:19 PM
GE refigerator no water dispensed richappy Refrigerator & Freezer Repair 0 03-21-2008 08:34 AM
Water Won't Dispense Ice Maker Works PAULUS1024 Refrigerator & Freezer Repair 5 11-26-2007 06:21 PM
ice maker works but slow jeffrey Refrigerator & Freezer Repair 1 08-10-2007 10:02 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
