Discuss
Ice maker problem
 in
Refrigerator & Freezer Repair
When the fridge was under warranty, the ice in the ice maker started freezing into a solid chunk. The technician
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice maker problem
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-15-2008, 07:37 AM
dlf dlf is offline
Junior Member
dlf is on a distinguished road
Default Ice maker problem
Model Number: KSRP25FNSS00   Brand: Kitchen Aid   Age: 1 - 5 years
When the fridge was under warranty, the ice in the ice maker started freezing into a solid chunk. The technician said the problem was with the little plastic door which opens to let the ice out. It was loose, allowing warm air into the ice maker.
The only solution, according to the technician, was to replace the entire freezer door! Well, this has happened again and the product is no longer under warranty. I called KitchenAid and, as you can imagine, found no help there.
Any suggestions?
Thank you.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-15-2008, 12:34 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Ice berg blues
I have come across simular problems in the past and most everytime it was a leaky water valve. A water valve will develope a faucet like drip on the ice and make it stick together. Easy solution: replace the water valve.a water valve double.jpg
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ice maker problem Ralmaroad Refrigerator & Freezer Repair 13 04-27-2008 10:05 AM
GE Ice Maker Problem cadknow Refrigerator & Freezer Repair 0 01-13-2008 08:48 AM
Ice Maker problem Tony Merkevicius Refrigerator & Freezer Repair 1 11-27-2007 12:26 PM
Ice Maker problem Claypoole Refrigerator & Freezer Repair 2 10-25-2007 04:05 AM
Ice maker problem scoots1925 Refrigerator & Freezer Repair 1 09-26-2007 09:22 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
