Discuss
Removing yoke from auger moter shaft
 in
Refrigerator & Freezer Repair
I have to replace the shelf the enclosure that holds the freezer ice bin, auger motor, .... How do I
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Removing yoke from auger moter shaft
  #1 (permalink)
Old 02-20-2010, 06:57 AM
Junior Member
bigart99 is on a distinguished road
Default Removing yoke from auger moter shaft
Model Number: MZD2766   Brand: Maytag   Age: 5 - 10 years
I have to replace the shelf the enclosure that holds the freezer ice bin, auger motor, .... How do I remove the yoke from the motor shaft?
Ads By Google
Related Models
Maytag MZD2766GEB REF - SXS/I&W
Maytag MZD2766GEQ REF - SXS/I&W
Maytag MZD2766GES REF - SXS/I&W
Maytag MZD2766GEW REF - SXS/I&W
Maytag MZD2768GEB REF - SXS/I&W
Maytag MZD2768GEQ REF - SXS/I&W
Maytag MZD2768GEW REF - SXS/I&W
Whirlpool N N ELECTRIC RANGES AND OVENS
Norge N1100PAW RANGE- F/S STD GAS
Norge N1100PRA RANGE- F/S STD GAS
Norge N1100PRA-L RANGE-F/S CONT CLEAN GAS
Norge N1100PRW RANGE- F/S STD GAS
Norge N1100PRW-L RANGE-F/S CONT CLEAN GAS
Norge N1500PRA RANGE- F/S STD ELE
Norge N1500PRW RANGE- F/S STD ELE
Norge N31100PAA RANGE- F/S STD GAS
Norge N31100PAW RANGE- F/S STD GAS
Norge N3110KRA RANGE- F/S STD GAS
Norge N3110KRW RANGE- F/S STD GAS
Norge N3110PPA RANGE- F/S STD GAS
Norge N3110PPW RANGE- F/S STD GAS
Norge N3110PRA RANGE- F/S STD GAS
Norge N3110PRW RANGE- F/S STD GAS
Norge N31111XAA RANGE- F/S STD GAS
Norge N31111XAW RANGE- F/S STD GAS
Norge N31115WAV RANGE- F/S STD GAS
Norge N31115XAA RANGE- F/S STD GAS
Norge N31115XAW RANGE- F/S STD GAS
Norge N3120SPA RANGE- F/S STD GAS
Norge N3120SPN RANGE- F/S STD GAS
Norge N3120SPW RANGE- F/S STD GAS
Norge N3120SRA RANGE- F/S STD GAS
Norge N3120SRW RANGE- F/S STD GAS
Norge N3121XPA RANGE- F/S STD GAS
Norge N3121XPW RANGE- F/S STD GAS
Norge N3121XRA RANGE- F/S STD GAS
Norge N3121XRW RANGE- F/S STD GAS
Norge N3121XTA RANGE- F/S STD GAS
Norge N3121XTW RANGE- F/S STD GAS
Norge N3137XRA RANGE- F/S STD GAS
Norge N3137XRW RANGE- F/S STD GAS
Roper N3157*0 Ranges, Electric*
Roper N3157*1 Ranges, Electric*
Roper N3157W0 Ranges, Electric*
Roper N3157W1 Ranges, Electric*
Norge N3177VUV RANGE- F/S STD GAS
Norge N3177XRA RANGE- F/S STD GAS
Norge N3177XRW RANGE- F/S STD GAS
Norge N3177XUA RANGE- F/S STD GAS
Norge N3177XUW RANGE- F/S STD GAS
Roper N3257*0 Ranges, Electric*
Roper N3257*1 Ranges, Electric*
Roper N3257W0 Ranges, Electric*
Roper N3257W1 Ranges, Electric*
Roper N3357*0 Ranges, Electric*
Roper N3357W0 Ranges, Electric*
Norge N3422PRA RANGE- S/C F/S GAS
Norge N3422PRW RANGE- S/C F/S GAS
Norge N3438SRA RANGE- S/C F/S GAS
Norge N3438SRW RANGE- S/C F/S GAS
Norge N3438VRV RANGE- S/C F/S GAS
Roper N3457*0 Ranges, Electric*
Roper N3457W0 Ranges, Electric*
Norge N3472SRA RANGE- S/C F/S GAS
Norge N3472SRW RANGE- S/C F/S GAS
Norge N3478VRV RANGE- S/C F/S GAS
Norge N3478VVV RANGE- S/C F/S GAS
Norge N3478XRA RANGE- S/C F/S GAS
Norge N3478XRW RANGE- S/C F/S GAS
Norge N3478XVA RANGE- S/C F/S GAS
Norge N3478XVW RANGE- S/C F/S GAS
Norge N3510KRA RANGE- F/S STD ELE
Norge N3510KRW RANGE- F/S STD ELE
Norge N3510PPA RANGE- F/S STD ELE
Norge N3510PPW RANGE- F/S STD ELE
Norge N3510PRA RANGE- F/S STD ELE
Norge N3510PRW RANGE- F/S STD ELE
Norge N3520SPA RANGE- F/S STD ELE
Norge N3520SPN RANGE- F/S STD ELE
Norge N3520SPW RANGE- F/S STD ELE
Norge N3520SRA RANGE- F/S STD ELE
Norge N3520SRW RANGE- F/S STD ELE
Norge N3521XPA RANGE- F/S STD ELE
Norge N3521XPW RANGE- F/S STD ELE
Norge N3521XRA RANGE- F/S STD ELE
Norge N3521XRW RANGE- F/S STD ELE
Norge N3832XRA RANGE- S/C F/S ELE
Norge N3832XRW RANGE- S/C F/S ELE
Norge N3875XRA RANGE- S/C F/S ELE
Norge N3875XRW RANGE- S/C F/S ELE
Norge N3878VRV RANGE- S/C F/S ELE
Norge N3878VVD RANGE- S/C F/S ELE
Norge N3878VVV RANGE- S/C F/S ELE
Norge N3878XRA RANGE- S/C F/S ELE
Norge N3878XRW RANGE- S/C F/S ELE
Norge N3878XVA RANGE- S/C F/S ELE
Norge N3878XVW RANGE- S/C F/S ELE
Magic Chef N40C-3-X9 MWAVE- CNTRTP / STAND ALONE
Norge N4231WRA RANGE-F/S CONT CLEAN GAS
Norge N4231WRW RANGE-F/S CONT CLEAN GAS
Norge N4251WTA RANGE- F/S STD GAS
Norge N4251WTW RANGE- F/S STD GAS
Roper N9157*0 Ranges, Electric*
Roper N9157*1 Ranges, Electric*
Roper N9157L0 Ranges, Electric*
Roper N9157L1 Ranges, Electric*
Roper N9157X0 Ranges, Electric*
Roper N9257*0 Ranges, Electric*
Roper N9257*1 Ranges, Electric*
Roper N9257*2 Ranges, Electric*
Roper N9257L1 Ranges, Electric*
Roper N9257L2 Ranges, Electric*
Roper N9257X0 Ranges, Electric*
Roper N9257X1 Ranges, Electric*
Roper N9357*0 Ranges, Electric*
Roper N9357*2 ELECTRIC RANGE
Roper N9357*3 Ranges, Electric*
Roper N9357L0 Ranges, Electric*
Roper N9357L2 ELECTRIC RANGE
Roper N9357L3 Ranges, Electric*
  #2 (permalink)
Old 02-20-2010, 07:23 AM
Junior Member
Default A quick tap with a hammer seemed to do the trick
It was probably not the correct way, but it worked.
  #3 (permalink)
Old 12-29-2010, 05:30 AM
Junior Member
mwc75574 is on a distinguished road
Default Auger shaft for the Yoke is "reverse threads"
I held the shaft with needle nose pliers and "tapped" the Yoke clockwise with a hammer and it came loose fine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Removing Ice crusher blades from old auger hyde Refrigerator & Freezer Repair 1 12-28-2010 06:13 PM
Removing speednut clip from auger susiep123 Refrigerator & Freezer Repair 0 09-15-2009 05:03 PM
Removing the spin shaft flange J1m Dishwasher Repair 4 05-04-2009 10:06 PM
Removing Bladed from end of Auger egbo76@yahoo.com Refrigerator & Freezer Repair 0 05-02-2009 12:52 PM
removing metal sleeve from shaft zaxxon Washer Repair 2 12-03-2008 05:23 AM
