Discuss
water pressure problem
 in
Refrigerator & Freezer Repair
my icemaker floods my freezer, from the icetray filler tube. i think the pressure is too strong. do i need
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » water pressure problem
  #1 (permalink)
Old 05-13-2008, 11:09 PM
tony sullivan tony sullivan is offline
Junior Member
tony sullivan is on a distinguished road
Question water pressure problem
Model Number: ET22RK/ET22RM   Brand: Whirlpool   Age: 5 - 10 years
my icemaker floods my freezer, from the icetray filler tube. i think the pressure is too strong. do i need a pressure regulator? or what?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-14-2008, 05:36 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Loosen the water line to the water solenoid in the back of fridge. and check the water pressure, if good pressure, replace the water solenoid. Also, make sure there is no voltage going to it from the ice maker.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water Does Not Stop/hose Disconnected To Pressure Switch JANEY2008 Washer Repair 1 05-13-2008 06:53 AM
High Pressure washer problem sundance@hughes.net General Talk 0 03-13-2008 11:33 AM
Noise, low pressure, etc romeroom Dishwasher Repair 0 11-19-2007 10:13 PM
Injector hose leaks when water pressure is low edpinarello Washer Repair 0 08-11-2007 12:13 AM
gas pressure adjusment tuta68 Oven Repair (including Ranges and Cooktops) 1 08-09-2007 06:50 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
