Discuss
my fridge stops getting cold and freezer stops freezing
 in
Refrigerator & Freezer Repair
My son has a side by side Frigidaire fridge/freezer w/ice maker that has been in storage for approxy
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » my fridge stops getting cold and freezer stops freezing
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-12-2008, 08:42 AM
peeka peeka is offline
Junior Member
peeka is on a distinguished road
Default my fridge stops getting cold and freezer stops freezing
Model Number: FRS26R2AW5   Brand: Frigidaire   Age: 1 - 5 years
My son has a side by side Frigidaire fridge/freezer w/ice maker that has been in storage for approxy 2 years. When he returned home from college and we hooked the appliance up it worked fine for a few days but has started not cooling or freezing. We have unplugged it for several hours and replugged and it will work for several hours just to stop again. It appears to be blowing out warm air. Any suggestions appreciated! TIA Peeka
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-12-2008, 09:36 AM
glen65 glen65 is offline
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
Check and make sure that the condenser fan underneath
the frig is running properly. You can get to it through the back.
  #3 (permalink)
Old 05-14-2008, 06:59 PM
Junior Member
Default fans running
The fan is running but after running this time approxy 16-24 hours the unit is now thawing the ice packs I have in the freezer. Can you think of anything else that it could be? Peeka
  #4 (permalink)
Old 05-15-2008, 03:18 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
When it stops, check if the compressor is running?
__________________
  #5 (permalink)
Old 05-15-2008, 03:37 AM
Junior Member
Default
where would the compressor be? Also the part that the water line attaches to started leaking last month so we took the water line off of it. Could this cause this behavior???
  #6 (permalink)
Old 05-15-2008, 06:21 AM
Senior Expert
APP Volunteer
Default
The compressor is underneath the refrigerator
in the back of the unit-close to the condenser fan,
there’s a picture below. When the unit
is trying to cool both of them should be running.
  #7 (permalink)
Old 05-15-2008, 07:28 PM
Junior Member
Default
I took a shot from under the fridge of the fan the compressor (i think) and also a wire plug in thingy thats not plugged into anything. Not sure what it is. When the unit is turned on the fan is running fine. The black thing if this is the compressor gets cool to touch. All the sounds coming from the unit sound normal. Is there a reset button? Also how can i tell if this is a defrost issue?? Thanks again Peeka
heres a photo of the bottom of the fridge with the parts written on for reference.
fridge.jpg photo - Peeka photos at pbase.com
  #8 (permalink)
Old 05-16-2008, 08:07 AM
Senior Expert
APP Volunteer
Default
Yes the black thing is the compressor.
Normally they are slightly warm when running, is that the case here?
Normally you will feel some vibration coming from it, is this the case?
  #9 (permalink)
Old 05-18-2008, 06:06 AM
Junior Member
Default
no it feels cool and i dont feel any vibrations from it.
  #10 (permalink)
Old 05-18-2008, 06:55 PM
okbobcats okbobcats is offline
Senior Expert
APP Volunteer
okbobcats is on a distinguished road
Default starter
on the side of the compressor. there is i little box with wires. check to see if you have 120 volts on one one the wires. most likly you do since for fan is running there. that little black or white boxis the starter for your compressor take it off and shake it. if something sounds loose in their its bad. that compressor you have has a lot of failures.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridge not cold on top and freezer not freezing ihavabadboy Refrigerator & Freezer Repair 1 11-27-2007 07:49 PM
freezer cold but not freezing, Fridge is ok USMCret. Refrigerator & Freezer Repair 5 10-27-2007 06:31 PM
Freezer works, Fridge won't Cool...fan stops Gamla33 Refrigerator & Freezer Repair 1 10-07-2007 12:15 PM
not freezing but fridge side nice and cold? mommame Refrigerator & Freezer Repair 1 09-10-2007 07:45 PM
Freezer fan stops ccfed3 Refrigerator & Freezer Repair 1 08-28-2007 04:14 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
