| » my fridge stops getting cold and freezer stops freezing |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: FRS26R2AW5 Brand: Frigidaire Age: 1 - 5 years
My son has a side by side Frigidaire fridge/freezer w/ice maker that has been in storage for approxy 2 years. When he returned home from college and we hooked the appliance up it worked fine for a few days but has started not cooling or freezing. We have unplugged it for several hours and replugged and it will work for several hours just to stop again. It appears to be blowing out warm air. Any suggestions appreciated! TIA Peeka
The fan is running but after running this time approxy 16-24 hours the unit is now thawing the ice packs I have in the freezer. Can you think of anything else that it could be? Peeka
The compressor is underneath the refrigerator
in the back of the unit-close to the condenser fan, there’s a picture below. When the unit is trying to cool both of them should be running. Last edited by glen65 : 05-15-2008 at 06:27 AM. |
I took a shot from under the fridge of the fan the compressor (i think) and also a wire plug in thingy thats not plugged into anything. Not sure what it is. When the unit is turned on the fan is running fine. The black thing if this is the compressor gets cool to touch. All the sounds coming from the unit sound normal. Is there a reset button? Also how can i tell if this is a defrost issue?? Thanks again Peeka
heres a photo of the bottom of the fridge with the parts written on for reference. fridge.jpg photo - Peeka photos at pbase.com |
on the side of the compressor. there is i little box with wires. check to see if you have 120 volts on one one the wires. most likly you do since for fan is running there. that little black or white boxis the starter for your compressor take it off and shake it. if something sounds loose in their its bad. that compressor you have has a lot of failures.
| Display Modes | |
| Fridge not cold on top and freezer not freezing | ihavabadboy | Refrigerator & Freezer Repair | 1 | 11-27-2007 07:49 PM |
| freezer cold but not freezing, Fridge is ok | USMCret. | Refrigerator & Freezer Repair | 5 | 10-27-2007 06:31 PM |
| Freezer works, Fridge won't Cool...fan stops | Gamla33 | Refrigerator & Freezer Repair | 1 | 10-07-2007 12:15 PM |
| not freezing but fridge side nice and cold? | mommame | Refrigerator & Freezer Repair | 1 | 09-10-2007 07:45 PM |
| Freezer fan stops | ccfed3 | Refrigerator & Freezer Repair | 1 | 08-28-2007 04:14 PM |
