no water to ice maker
My ice maker quit working about two weeks ago. I can fill the tray manually by crossing test points L and V, and let the ice make and everything will cycle and dump the ice, but wont fill tray.
While cycling I tested points N and V and get about 116 volts, I tested the thermostat while cold and had continuity. Also the water dispenser acts up some times you have to push the button several time to make it work, don't know if the problem is connected or not. The ice maker quit about a year ago and I replaced the module and it fixed it but now it quit again. |
| All times are GMT -7. The time now is 01:08 AM. |
