Discuss
Water Dispenser Wont stop after removing cup
 in
Refrigerator & Freezer Repair
Hi, great site here where people can help each other out! Have an issue where once you dispense the water
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water Dispenser Wont stop after removing cup
  #1 (permalink)
Old 05-11-2008, 09:04 PM
DaBull DaBull is offline
Junior Member
DaBull is on a distinguished road
Default Water Dispenser Wont stop after removing cup
Model Number: TFB26PPDABB   Brand: GE   Age: 5 - 10 years
Have an issue where once you dispense the water into a cup and remove it, the water continues flowing for 2-4 seconds after removing glass from push switch. Never used to do this before, only started after I recently replaced filter. Tried removing line and blowing through it. Checked to see if filter was on correct. Any other suggestions? Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-12-2008, 06:12 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
You have to remove about 11/2 gallons of water after you replaced the water filter. Did you do it?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 05-12-2008, 06:56 PM
Junior Member
Default
How do you remove that water? Thank you for your reply! After I removed filter I tried pushing in push lever with cup, but only a few drips came out.
  #4 (permalink)
Old 05-13-2008, 01:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The water dispensing system would not work without a water filter unless you installed the bypass plug instead.
You have to use the water dispenser to remove water from the system.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Removing fascia around ice and water dispenser dlanotte Refrigerator & Freezer Repair 1 04-19-2008 08:30 AM
water dispenser will not stop leaking 1beth1 Refrigerator & Freezer Repair 3 01-26-2008 05:14 PM
Water wont stop running chrisaz1977 Dishwasher Repair 1 12-12-2007 11:58 AM
removing cover off front of water/ice dispenser need4help Refrigerator & Freezer Repair 1 11-02-2007 11:48 AM
water dispenser wont turn off kortneylee Refrigerator & Freezer Repair 0 09-07-2007 09:55 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
