Discuss
Freezer will not Freeze
 in
Refrigerator & Freezer Repair
Attempting to repair freezer that won't freeze. Findings: Defrost timer was replaced with wrong timer (Plug pin seq. different)
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer will not Freeze
  #1 (permalink)
Old 05-09-2008, 08:35 PM
Earl Dryer Earl Dryer is offline
Junior Member
Earl Dryer is on a distinguished road
Default Freezer will not Freeze
Model Number: 253.9280411   Brand: Kenmore   Age: 1 - 5 years
Defrost timer was replaced with wrong timer (Plug pin seq. different) don't know if previous person changed wiring in plug, my guess is that he didn't. Freezer didn't work after his repair. Continuity test on timer show bad.
Evap. coil freezes up at the cap tube to the defrost T-stat. My old A/C day I seem to recall that a freeze at the expansion valve or cap tube was generally an indication of a restriction or low charge. I see no indication of leakage any where. I hope I'm just on a witch hunt and the refrigerant system is OK. I ordered a new timer the original timers test was ?
All imput appreciated!
Related Models
Kenmore 25312021101 FREEZER
Kenmore 25312541100 FREEZER
Kenmore 25312541102 SEARS/FREEZER
Kenmore 25312551100 FREEZER
Kenmore 25313051100 FREEZER
Kenmore 25313312101 FREEZER
Kenmore 25313351100 FREEZER
Kenmore 25313541101 FREEZER
Kenmore 25313551100 FREEZER
Kenmore 25313711100 FREEZER
Kenmore 25313712100 FREEZER
Kenmore 25313911100 FREEZER
Kenmore 25318331002 CHEST FREEZER
Kenmore 25318331890 CHEST FREEZER
Kenmore 25318331891 CHEST FREEZER
Kenmore 25318351004 CHEST FREEZER
Kenmore 25318351005 FREEZER
Kenmore 25318351006 FREEZER
Kenmore 25319321002 CHEST FREEZER
Kenmore 25319321003 FREEZER
Kenmore 25319321004 CHEST FREEZER
Kenmore 25319321990 CHEST FREEZER
Kenmore 25319321991 FREEZER
Kenmore 25319331000 CHEST FREEZER
Kenmore 25319501990 CHEST FREEZER
Kenmore 25319501991 FREEZER
Kenmore 25319501992 FREEZER
Kenmore 25319531003 CHEST FREEZER
Kenmore 25319531990 CHEST FREEZER
Kenmore 25319531991 CHEST FREEZER
Kenmore 25319531994 CHEST FREEZER
Kenmore 25319531995 FREEZER
Kenmore 25319701990 CHEST FREEZER
Kenmore 25319701991 FREEZER
Kenmore 25319821004 CHEST FREEZER
Kenmore 25319821990 CHEST FREEZER
Kenmore 25319821991 CHEST FREEZER
Kenmore 25319821992 FREEZER
Kenmore 25319821995 CHEST FREEZER
Kenmore 25321201100 FREEZER
Kenmore 25321201102 FREEZER
Kenmore 25321211100 UPRIGHT FREEZER
Kenmore 25321211101 FREEZER
Kenmore 25321401100 FREEZER
Kenmore 25321401101 FREEZER
Kenmore 25321402100 FREEZER
Kenmore 25321402101 FREEZER
Kenmore 25321402102 FREEZER
Kenmore 25321402103 FREEZER
Kenmore 25321411100 FREEZER
Kenmore 25321411101 FREEZER
Kenmore 25321411102 FREEZER
Kenmore 25321411103 FREEZER
Kenmore 25321411104 FREEZER
Kenmore 25321421100 FREEZER
Kenmore 25321421101 FREEZER
Kenmore 25321421102 FREEZER
Kenmore 25321421103 FREEZER
Kenmore 25321421104 FREEZER
Kenmore 25321421105 FREEZER
Kenmore 25321711100 FREEZER
Kenmore 25321711101 FREEZER
Kenmore 25321711102 FREEZER
Kenmore 25321711103 FREEZER
Kenmore 2532230 AIR CLEANERS/DEODORIZERS
Kenmore 25322401100 FREEZER
Kenmore 25322401101 SEARS/FREEZER
Kenmore 25322402100 FREEZER
Kenmore 25322411100 FREEZER
Kenmore 25322411101 FREEZER
Kenmore 25322411102 SEARS/FREEZER
Kenmore 25323024100 FREEZER
Kenmore 25323082100 FREEZER
Kenmore 25323114100 FREEZER
Kenmore 25323414100 FREEZER
Kenmore 25323424100 FREEZER
Kenmore 25323425100 FREEZER
Kenmore 25323714100 FREEZER
Kenmore 25323724100 FREEZER
Kenmore 25323725100 FREEZER
Kenmore 25329082990 UPRIGHT FREEZER
Kenmore 25329082991 UPRIGHT FREEZER
Kenmore 25329082992 FREEZER
Kenmore 25329082993 FREEZER
Kenmore 25329082994 FREEZER
Kenmore 25329101990 UPRIGHT FREEZER
Kenmore 25329101992 UPRIGHT FREEZER
Kenmore 25329101993 FREEZER
Kenmore 25329101994 UPRIGHT FREEZER
Kenmore 25329111990 UPRIGHT FREEZER
Kenmore 25329111991 FREEZER
Kenmore 25329111992 UPRIGHT FREEZER
Kenmore 25329121990 UPRIGHT FREEZER
Kenmore 25329201000 UPRIGHT FREEZER
Kenmore 25329201001 UPRIGHT FREEZER
Kenmore 25329201002 UPRIGHT FREEZER
Kenmore 25329401990 UPRIGHT FREEZER
Kenmore 25329401991 FREEZER
Kenmore 25329401992 UPRIGHT FREEZER
Kenmore 25329711990 UPRIGHT FREEZER
Kenmore 25329711991 FREEZER
Kenmore 25329711992 UPRIGHT FREEZER
Kenmore 25331113300 REFRIGERATOR
Kenmore 25331115300 REFRIGERATOR
Kenmore 25331123300 REFRIGERATOR
Kenmore 25331125300 REFRIGERATOR
Kenmore 25331133300 REFRIGERATOR
Kenmore 25331135300 REFRIGERATOR
Kenmore 25331143300 REFRIGERATOR
Kenmore 25331145300 REFRIGERATOR
Kenmore 25336600890 TOP MOUNT REFRIGERATOR
Kenmore 25336600891 TOP MOUNT REFRIGERATOR
Kenmore 25336600892 TOP MOUNT REFRIGERATOR
Kenmore 25336600894 TOP MOUNT REFRIGERATOR
Kenmore 25336600895 TOP MOUNT
Kenmore 25336600896 REFRIGERATOR
Kenmore 25336600898 TOP MOUNT REFRIGERATOR
Kenmore 25336601890 TOP MOUNT REFRIGERATOR
Kenmore 25336601891 TOP MOUNT REFRIGERATOR
Kenmore 25336601892 TOP MOUNT REFRIGERATOR
  #2 (permalink)
Old 05-10-2008, 06:00 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Hi Earl,
Sounds like there is a restriction or a low charge. In order to find out exactly you have to check the pressure in the system on both sides.
__________________
  #3 (permalink)
Old 05-17-2008, 08:03 PM
Junior Member
Default Thank you Gene
The old gears are starting to work again (starting to remember again), I was right the dryer was full and had moisture clogging the cap tube, Thanks for your reenforcement, I slaid the witch.
Earl
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Refrigerator drain freeze problem Scottrse1 Refrigerator & Freezer Repair 11 09-26-2009 05:21 PM
Defrost drain continues to freeze up KEITHWI Refrigerator & Freezer Repair 0 04-11-2008 06:08 PM
GE Refrigerator won't cool or freeze top half embalmer Refrigerator & Freezer Repair 3 12-30-2007 08:19 PM
coil freeze up a/c guy Refrigerator & Freezer Repair 3 11-25-2007 09:22 AM
no cold or freeze tms Refrigerator & Freezer Repair 2 11-07-2007 09:31 AM
