Discuss
Freezer will not Freeze
 in
Refrigerator & Freezer Repair
Attempting to repair freezer that won't freeze. Findings: Defrost timer was replaced with wrong timer (Plug pin seq. different)
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer will not Freeze
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-09-2008, 07:35 PM
Earl Dryer Earl Dryer is offline
Junior Member
Earl Dryer is on a distinguished road
Default Freezer will not Freeze
Model Number: 253.9280411   Brand: Kenmore   Age: 1 - 5 years
Defrost timer was replaced with wrong timer (Plug pin seq. different) don't know if previous person changed wiring in plug, my guess is that he didn't. Freezer didn't work after his repair. Continuity test on timer show bad.
Evap. coil freezes up at the cap tube to the defrost T-stat. My old A/C day I seem to recall that a freeze at the expansion valve or cap tube was generally an indication of a restriction or low charge. I see no indication of leakage any where. I hope I'm just on a witch hunt and the refrigerant system is OK. I ordered a new timer the original timers test was ?
All imput appreciated!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-10-2008, 05:00 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Earl,
Sounds like there is a restriction or a low charge. In order to find out exactly you have to check the pressure in the system on both sides.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 05-17-2008, 07:03 PM
Junior Member
Default Thank you Gene
The old gears are starting to work again (starting to remember again), I was right the dryer was full and had moisture clogging the cap tube, Thanks for your reenforcement, I slaid the witch.
Earl
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Defrost drain continues to freeze up KEITHWI Refrigerator & Freezer Repair 0 04-11-2008 05:08 PM
GE Refrigerator won't cool or freeze top half embalmer Refrigerator & Freezer Repair 3 12-30-2007 07:19 PM
Amana Refrigerator drain freeze problem Scottrse1 Refrigerator & Freezer Repair 2 12-09-2007 07:20 AM
coil freeze up a/c guy Refrigerator & Freezer Repair 3 11-25-2007 08:22 AM
no cold or freeze tms Refrigerator & Freezer Repair 2 11-07-2007 08:31 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
