Discuss
Direction of Fan Blades on Evaporator Motor
 in
Refrigerator & Freezer Repair
Bought a new evaporator fan from this site, and it came in 2 pieces consisting of the motor and the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Direction of Fan Blades on Evaporator Motor
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-09-2008, 12:09 PM
Longjack Longjack is offline
Junior Member
Longjack is on a distinguished road
Default Direction of Fan Blades on Evaporator Motor
Brand: Whirlpool   Age: Less than 1 year
Bought a new evaporator fan from this site, and it came in 2 pieces consisting of the motor and the fan blade.
What is the correct position for installing the fan blade back on the motor spindle - another words, which way should the blade points be facing?
Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-10-2008, 04:36 PM
Earl Dryer Earl Dryer is offline
Junior Member
Earl Dryer is on a distinguished road
Default
Not to sound like a smart ass but, I would recommend installing it like the old unit.
  #3 (permalink)
Old 05-11-2008, 03:03 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You take the new motor, with installed fan blade and plug it in the wall outlet, if blade is installed right, it will blow air. When installed in the fridge. it must direct air into the refrigerator and the freezer. If the motor turns the wrong way, you must reverse the armature, if the motor can be taken apart.
__________________
  #4 (permalink)
Old 05-12-2008, 03:09 AM
Junior Member
Default
Thanks for the respones, and no I appreciate the advice about matching the old setup. However, I must be somethng short of a dumb *** as I took out the old one to clean it and in dis-assembly - never paid attention to which way the blades went, so have never been sure about the original configutation. Then I thought about whether to test by blowing or sucking in, and again was not sure which it should be... so in any event - thanks to both of you!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Evaporator motor part #wr60x10185 seahawkman Refrigerator & Freezer Repair 5 01-16-2008 01:12 AM
Evaporator Motor GaryDolman Refrigerator & Freezer Repair 5 01-15-2008 09:49 AM
Evaporator Fan Motor chagan Refrigerator & Freezer Repair 1 01-08-2008 07:20 PM
Direction for Sidewinder Motor SPUD Dishwasher Repair 2 10-24-2007 03:07 PM
evaporator fan motor niose toner Refrigerator & Freezer Repair 0 10-18-2007 09:46 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
