Discuss
freezer fan running nearly 24hrs;stops 2Xper day
 in
Refrigerator & Freezer Repair
My bottom freezer is frost free model about 10 1/2 yrs old. Refrigerator is constantly running, except once in
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » freezer fan running nearly 24hrs;stops 2Xper day
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-05-2008, 05:03 PM
FrankK FrankK is offline
Junior Member
FrankK is on a distinguished road
Question freezer fan running nearly 24hrs;stops 2Xper day
Model Number: BCI20TW   Brand: Amana   Age: More than 10 years
My bottom freezer is frost free model about 10 1/2 yrs old. Refrigerator is constantly running, except once in am and once at night it stops. Noticed ice cream getting soft. temperature in empty fridge was 28 degrees and empty freezer was 20 degrees 24 hrs after restarting. Where should troubleshooting begin?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-05-2008, 06:51 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Check if there is frost on the back panel in the freezer.
Post your findings.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 05-06-2008, 10:06 AM
Junior Member
Default
No frost on the back of the freezer.
  #4 (permalink)
Old 05-06-2008, 01:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Frank,
Looks like the sealed system is low on Freon. In such situation all diagnosis should be done by a certified tech and it could be very costly.
__________________
  #5 (permalink)
Old 05-07-2008, 06:34 AM
Junior Member
Default
Thanks Gene.
Is there a freezer setting or possibly turning the freezer to "OFF" that will support using the refrigerator until the freon is checked? Frank
  #6 (permalink)
Old 05-07-2008, 01:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Frank,
There is only one cooling system for both parts and you can not turn off just one of them.
__________________
  #7 (permalink)
Old 05-08-2008, 06:56 AM
Junior Member
Default
Gene,
I understand why low freon will cause the freezer to run constantly and not reach the correct temperature, do you know why the system would stop twice a day: once in morning @10AM and again in the evening?
Frank
  #8 (permalink)
Old 05-13-2008, 09:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Frank,
It stops due to automated defrost, operated by the defrost timer.
__________________
  #9 (permalink)
Old 05-27-2008, 10:24 AM
Junior Member
Thumbs up
Gene,
Thanks to your recommendation to contact a Certified Tech, he found the Filter Restricted and repaired problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer keeps running starnosky Refrigerator & Freezer Repair 1 02-27-2008 08:15 AM
danby fridge fan in freezer not running 7336990 Refrigerator & Freezer Repair 1 01-08-2008 04:52 PM
Freezer compressor not running thenninger Refrigerator & Freezer Repair 1 12-20-2007 02:11 AM
Freezer fan stops ccfed3 Refrigerator & Freezer Repair 1 08-28-2007 04:14 PM
Dryer stops running after letting off the Start button Andy Dryer Repair 10 08-01-2007 09:56 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
