Discuss
whirlpool fridge gt2shmxms04 freezer warmed and frosting freezer help
 in
Refrigerator & Freezer Repair
I woke up the other day and the unit was not as cold as it normally was and there was
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » whirlpool fridge gt2shmxms04 freezer warmed and frosting freezer help
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-05-2008, 01:02 PM
ianandamy ianandamy is offline
Junior Member
ianandamy is on a distinguished road
Default whirlpool fridge gt2shmxms04 freezer warmed and frosting freezer help
Model Number: gt2shmxms04   Brand: Whirlpool   Age: 1 - 5 years
I woke up the other day and the unit was not as cold as it normally was and there was frost in the freezer and the ice cream was soft.
I opened the back and removed the front grill and cleaned the coils and verified the compressor was runing, fan was runing, compressor is hot, start and relay are good. the drain is working and the coil is not frozen and evap fan is working.
I ended up turning the thermostat up to just before max, it worked after about 5 hours it became stable. and the only abnormal issue is the freezer is frosting a little on the items.
Any help would be great.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-05-2008, 06:13 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
I would recommend to buy two refrigerator thermometers and keep them always inside to control temperatures in the freezer and in the fresh food compartment. Normally it suppose to be about 0°F in the freezer and between 36°F to 40°F in the fresh food compartment.
Adjust the controls if needed and be advised that it takes about 24 hours to see the result.
- The part number for the refrigerator & freezer thermometer is AP3549145
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 05-05-2008, 06:53 PM
Junior Member
Default
I have had this fridge for 2 years it has never been changed on the temps and yesterday morning the unit started running warmer and the ice cream was very soft fridge was like 60 degrees. I was thinking more along the lines of a defrost control circuit issue or heater is out.
I dont think thermometers are going to fix the issue. right now the freezer is +12 degrees and the fridge is 50 degrees. However the temp switch is maxed out to get it there. when it was set where it was for two years it was colder than this and it was at 3 out of 5 on the temp setting.
thanks for your reply pleaselet me know what you think further.
  #4 (permalink)
Old 05-07-2008, 02:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If there is frost in the back of the freezer then the problem is a faulty defrost system. If there is no frost then the cooling (sealed) system is low on Freon.
If this is Freon issue and your fridge is less then 5 years, then it's steel under the manufacturer warranty and you have to call Whirlpool for a free service.
If this is a problem with the defrost system - let us know.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridge OK Freezer temps vary widely slow ice and slow freezer fan start shado118 Refrigerator & Freezer Repair 2 04-24-2008 05:07 PM
fridge and freezer not cooling estock Refrigerator & Freezer Repair 7 03-30-2008 11:11 AM
Back Freezer wall keeps frosting up arnesons Refrigerator & Freezer Repair 2 03-11-2008 07:40 AM
Sub Zero 201 FD Freezer is not freezing and coils are frosting over/freezing up badace Refrigerator & Freezer Repair 1 12-02-2007 09:54 AM
freezer frosting refrig not cooling keodonn Refrigerator & Freezer Repair 1 10-13-2007 11:30 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
