freezer door left open, stopped cooling properly. switched unit off for 12 hours, restarted. freezer still does not cool properly. Ice will not make. There is a hollow aluminum tube above the ice tray inside the ice maker that is hot. I suspect this is keeping the temp up (bottom of freezer is cold). Is this tube part of the ice maker assembly or a separate part. This is what I am trying to figure out so I can order. Please help!! thank you
