The defrost thermostat was replaced at 4 yrs. old. It appears to need replacement again (4-5 yrs. later). Should the defrost thermostat be properly placed on the evap. coil end that is the supply from the condensor or the return end. Presumably the coil end at the back, which gets cold first, is the supply side from the condensor. Thanks.
THIS FORUM IS DEAD!!!!!!! |
Thanks Denman. Could you possibly send the manual again. I think you sent two copies of the Tech Bulletin. Thanks, Mark
