Discuss
Freezer not below 69, relay clicking
 in
Refrigerator & Freezer Repair
I have a Maytag side by side that has worked fine for the past 4years then last night the compressor
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer not below 69, relay clicking
  #1 (permalink)
Old 04-25-2008, 09:38 PM
FLhelp FLhelp is offline
Junior Member
FLhelp is on a distinguished road
Default Freezer not below 69, relay clicking
Model Number: MZD2766GES   Brand: Maytag   Age: 1 - 5 years
I have a Maytag side by side that has worked fine for the past 4years then last night the compressor relay began clicking, the compressor gets very warm but it is only blowing 69 degree air into the freezer. A visual inspection of the relay shows burnt marks around the contacts (one side with peicies of plastic falling out). Any thought on this being the problem or could the capacitor/compressor be the problem? THANKS!
Related Models
Maytag MZD2766GES Ref - SXS/I&W
Maytag MZD2766GEW Ref - SXS/I&W
Maytag MZD2768GEB Ref - SXS/I&W
Maytag MZD2768GEQ Ref - SXS/I&W
Maytag MZD2768GEW Ref - SXS/I&W
Norge N1100PAW Range - F/s Std Gas
Norge N1100PRA Range - F/s Std Gas
Norge N1100PRA-L Range - F/s Cont Clean Gas
Norge N1100PRW Range - F/s Std Gas
Norge N1100PRW-L Range - F/s Cont Clean Gas
Norge N1500PRA Range - F/s Std Ele
Norge N1500PRW Range - F/s Std Ele
Norge N31100PAA Range - F/s Std Gas
Norge N31100PAW Range - F/s Std Gas
Norge N3110KRA Range - F/s Std Gas
Norge N3110KRW Range - F/s Std Gas
Norge N3110PPA Range - F/s Std Gas
Norge N3110PPW Range - F/s Std Gas
Norge N3110PRA Range - F/s Std Gas
Norge N3110PRW Range - F/s Std Gas
Norge N31111XAA Range - F/s Std Gas
Norge N31111XAW Range - F/s Std Gas
Norge N31115WAV Range - F/s Std Gas
Norge N31115XAA Range - F/s Std Gas
Norge N31115XAW Range - F/s Std Gas
Norge N3120SPA Range - F/s Std Gas
Norge N3120SPN Range - F/s Std Gas
Norge N3120SPW Range - F/s Std Gas
Norge N3120SRA Range - F/s Std Gas
Norge N3120SRW Range - F/s Std Gas
Norge N3121XPA Range - F/s Std Gas
Norge N3121XPW Range - F/s Std Gas
Norge N3121XRA Range - F/s Std Gas
Norge N3121XRW Range - F/s Std Gas
Norge N3121XTA Range - F/s Std Gas
Norge N3121XTW Range - F/s Std Gas
Norge N3137XRA Range - F/s Std Gas
Norge N3137XRW Range - F/s Std Gas
Norge N3137XUA Range - F/s Std Gas
Norge N3137XUW Range - F/s Std Gas
Whirlpool N3157W0
Whirlpool N3157W1
Whirlpool N3157^0
Whirlpool N3157^1
Norge N3177VUV Range - F/s Std Gas
Norge N3177XRA Range - F/s Std Gas
Norge N3177XRW Range - F/s Std Gas
Norge N3177XUA Range - F/s Std Gas
Norge N3177XUW Range - F/s Std Gas
Whirlpool N3257W0
Whirlpool N3257W1
Whirlpool N3257^0
Whirlpool N3257^1
Whirlpool N3357W0
Whirlpool N3357^0
Norge N3422PRA Range - S/c F/s Gas
Norge N3422PRW Range - S/c F/s Gas
Norge N3438SRA Range - S/c F/s Gas
Norge N3438SRW Range - S/c F/s Gas
Norge N3438VRV Range - S/c F/s Gas
Whirlpool N3457W0
Whirlpool N3457^0
Norge N3472SRA Range - S/c F/s Gas
Norge N3472SRW Range - S/c F/s Gas
Norge N3478VRV Range - S/c F/s Gas
Norge N3478VVV Range - S/c F/s Gas
Norge N3478XRA Range - S/c F/s Gas
Norge N3478XRW Range - S/c F/s Gas
Norge N3478XVA Range - S/c F/s Gas
Norge N3478XVW Range - S/c F/s Gas
Norge N3510KRA Range - F/s Std Ele
Norge N3510KRW Range - F/s Std Ele
Norge N3510PPA Range - F/s Std Ele
Norge N3510PPW Range - F/s Std Ele
Norge N3510PRA Range - F/s Std Ele
Norge N3510PRW Range - F/s Std Ele
Norge N3520SPA Range - F/s Std Ele
Norge N3520SPN Range - F/s Std Ele
Norge N3520SPW Range - F/s Std Ele
Norge N3520SRA Range - F/s Std Ele
Norge N3520SRW Range - F/s Std Ele
Norge N3521XPA Range - F/s Std Ele
Norge N3521XPW Range - F/s Std Ele
Norge N3521XRA Range - F/s Std Ele
Norge N3521XRW Range - F/s Std Ele
Norge N3832XRA Range - S/c F/s Ele
Norge N3832XRW Range - S/c F/s Ele
Norge N3875XRA Range - S/c F/s Ele
Norge N3875XRW Range - S/c F/s Ele
Norge N3878VRV Range - S/c F/s Ele
Norge N3878VVD Range - S/c F/s Ele
Norge N3878VVV Range - S/c F/s Ele
Norge N3878XRA Range - S/c F/s Ele
Norge N3878XRW Range - S/c F/s Ele
Norge N3878XVA Range - S/c F/s Ele
Norge N3878XVW Range - S/c F/s Ele
Magic Chef N40C-3-X9 Mwave - Cntrtp / Stand Alone
Norge N4231WRA Range - F/s Cont Clean Gas
Norge N4231WRW Range - F/s Cont Clean Gas
Norge N4251WTA Range - F/s Std Gas
Norge N4251WTW Range - F/s Std Gas
Whirlpool N9157L0
Whirlpool N9157L1
Whirlpool N9157X0
Whirlpool N9157^0
Whirlpool N9157^1
Whirlpool N9257L1
Whirlpool N9257L2
Whirlpool N9257X0
Whirlpool N9257X1
Whirlpool N9257^0
Whirlpool N9257^1
Whirlpool N9257^2
Whirlpool N9357L0
Whirlpool N9357L2
Whirlpool N9357L3
Whirlpool N9357^0
Whirlpool N9357^2
Whirlpool N9357^3
Whirlpool N9457L3
  #2 (permalink)
Old 04-26-2008, 01:44 PM
gearhead1218 gearhead1218 is offline
Member
gearhead1218 is on a distinguished road
Default
First change out the relay and overload. If that don't fix it then the compressor is bad and will need replacement.
If it's less than 5 years old the compressor will be under warranty
  #3 (permalink)
Old 04-27-2008, 04:03 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You can order the start device on this site. Part # AP3964068 Should fix your problem, just make sure the run capacitor is still wired between the compressor start and run pins.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer not powering...Clicking ryno1280 Refrigerator & Freezer Repair 1 04-24-2008 04:05 PM
ge freezer fan clicking bhgewilson Refrigerator & Freezer Repair 1 03-19-2008 07:37 PM
Refrig/freezer clicking on/off every 5 to 10min Swiny20 Refrigerator & Freezer Repair 1 03-02-2008 03:36 PM
freezer not cooling/making clicking sound momof1 Refrigerator & Freezer Repair 3 12-12-2007 02:36 PM
freezer/refrigeratornot cooling, motor running with clicking sound intermittent counterbob20 Refrigerator & Freezer Repair 2 10-07-2007 01:23 PM
