Recently I had to "de-ice" evaporator coil. There is one green grounding wire on the top attached to evaporator cover panel. When I was checking heater/defroster I found another green grounding wire on the bottom of the right freezer wall. This wire was coming out from rectangular opening in the wall. I do not recall disconecting this wire. Should this grounding wire be connected to something or hidded in the wall? If connected, please tell me where. Please help!
