We use a reverse osmosis wter system. Our ice maker froze after Thanksgiving, a repair man came out and fixed it. Since we use this type of water system we were told that if the pressure is two low there is not enough pressure to completely close the water supply so consequently it will freeze and water cannot flow into the icemaker. The repair man removed the icemaker, melted the ice, and we were good to go. It is frozen again. I need to know how to remove the icemaker, so we can fix this ourselves. The solution was simple, and cnaces are it will happen again. So please give me directions on how to remove it.
