| » noisy evap fan motor with excessive vibration |
Model Number: BX21VC Brand: Amana Age: More than 10 years
The freezer evap fan motor is vibrating excessively causing a continuous loud noise when running. I tightened all housing screws and the back panel on the inside of the freezer and the plastic guide for the fan output. This only helped a little. Could the bearings on the fan motor be going. It has been getting worse over the past few weeks but now it is very bad that it is easily heared on the second floor of the house at the opposite end. Any advise is appreciated. Thank you.
Replacement parts for AMANA BX21VC Ref - Bottom Mounts | AppliancePartsPros.com Does sound like the fan is shot, I would replace it, It3em 32 in Section 5. Part number: AP4008960 Click on the picture for more views of the part.
__________________
I would pull the whole fan/motor assembly out and put 115 volts to it with a cheater cord, you might have a unbalanced fan blade or bad rubber end bell supports. If there is play in the motor shaft, or it screaches, replace the motor.
__________________
| Display Modes | |
| Excessive Vibration | mark987 | Washer Repair | 1 | 12-31-2009 04:59 PM |
| washing machine excessive vibration spin cycle | gary293 | Washer Repair | 0 | 03-06-2009 01:29 PM |
| Excessive vibration | Tanneme | Washer Repair | 0 | 02-15-2009 11:30 AM |
| Noisy Evap Fan | hamm_6869 | Refrigerator & Freezer Repair | 5 | 09-19-2008 12:07 PM |
| Excessive Vibration | doradofisher | Washer Repair | 1 | 08-07-2008 03:45 AM |
