dadof6
#1 Posted : Friday, January 29, 2010 8:54:27 AM(UTC)
dadof6
I replaced the original Whirlpool ice maker with one of your kits (AP2984633) back in July of 09'. It stopped working in November of 09'. Another replacement kit was shipped to me and I installed it. Still has not work. I've replaced the water valve as well and we still do not having water being drawn from/thru the valve into the unit to make the ice. The unit does turn and would dump ice, if there were any to dump. Where do I go from here? Could the kit be defective or a portion of it? Is there a way to troubleshoot the unit for this issue or should I just re-order another replacement kit?
#2 Posted : Friday, January 29, 2010 10:53:21 AM(UTC)
Have you checked the water feeding tube which comes into the ice maker?
What is the complete model number of the refrigerator?
dadof6
#3 Posted : Monday, February 1, 2010 4:59:44 AM(UTC)
dadof6
Yes, I checked the inlet tube and there are no kinks in the line. I also removed the tube and ran a small wire through the back side of the fridge into the ice maker to be sure there were no obstructions. I also blew through the top of the tube back down to the valve and found no blockage. We have water being distributed to the water dispenser in the door but not to the ice maker itself. As I mentioned before, the inlet valve has been replaced as well. The model number is KSRS25QAWH10.
dadof6
#4 Posted : Monday, February 1, 2010 1:02:54 PM(UTC)
dadof6
SEE BELOW.
Any suggestions?
#5 Posted : Thursday, February 4, 2010 11:12:15 AM(UTC)
Sorry for the delay.
Swap the wires on the water valve solenoids. Press the water release for the water dispenser for a few seconds and check if there is water in the ice maker. Post the results.
dadof6
#6 Posted : Monday, February 8, 2010 11:07:56 AM(UTC)
dadof6
I tried swapping the connections as you suggested but the connections
are of different sizes so only one could be made. Here's what was possible. I connected the ice maker connection to the water dispenser side of the inlet valve. I pushed the water release (held it down) but no water was distributed into the ice maker or through water dispenser on front of unit. I left this connected that way fo awhile. When the ice maker went through its cycle and would normally want water dispensed to the ice maker, the water was dispensed through the water dispenser (onto the floor!!) and not into the ice maker.
I tried this process with both the new and the old inlet valves and I got the same results.
#7 Posted : Monday, February 8, 2010 11:37:24 AM(UTC)
You may want to carefully use two wires to connect the wire plug to the second solenoid. This is the easiest way to test what is wrong.
dadof6
#8 Posted : Monday, February 8, 2010 12:18:48 PM(UTC)
dadof6
Will do and will post results on Tuesday.
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest 3/11/2024 8:34:02 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla 2/16/2024 8:36:50 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Ice maker fiil/dump (Refrigerator & Freezer Repair)
by Guest 2/12/2024 5:46:50 AM(UTC)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 1/3/2024 11:45:50 AM(UTC)
Whirlpool Gold Side by Side (GSS26C4XXF03/HR14386344) Door Ice Maker Troubleshooting (Refrigerator & Freezer Repair)
by ForumUser1 12/25/2023 11:44:03 AM(UTC)
Need service code to defrost Electrolux ice maker, EI23BC56ISB (Refrigerator & Freezer Repair)
by Guest 12/16/2023 12:29:49 PM(UTC)
Wiring harness clip KitchenAid freestanding ice maker KUIC18NNZS0 (Appliance Parts)
by GADIY 12/5/2023 12:02:09 PM(UTC)
Ice Maker Arm trapped down, started to flood, Now won't work... help (Refrigerator & Freezer Repair)
by jimtmcdaniels 12/5/2023 7:20:56 AM(UTC)
