| » Frig not running |
Model Number: ED25PEXHB00 Brand: Whirlpool Age: 5 - 10 years
Frig has power to it. All lights are on. However, the condenser fan, evaporator fan and compressor are not running. At first I thought it was the defrost timer but after changing it the frig still does not run. Any other ideas would be helpful
Replacement parts for WHIRLPOOL ED25PEXHB00 | AppliancePartsPros.com Here is a wiring diagram http://www.servicematters.com/docs/w...%202204338.pdf At first I thought it was the defrost timer but after changing it the frig still does not run. Did you try advancing the timer cam manually with a screwdriver as it does sound like you are in a defrost cycle. Looks like a lot of things run through the thermostat my guess would be that the defrost timer will not advance unless the thermostat is closed. Also looks like the unit cycles the compressor, condenser fan and evaporator fan all together. If advancing the defrost timer did not start up the compressor etc. could be your thermostat is toast.
__________________
| Display Modes | |
| Maytag Frig, water on door won't stop running | bobinkcmo | Refrigerator & Freezer Repair | 1 | 10-07-2008 03:30 PM |
| whirlpool frig compressor not running | jim45 | Refrigerator & Freezer Repair | 5 | 09-22-2008 09:23 AM |
| GE frig, compressor not running | rmila75 | Refrigerator & Freezer Repair | 0 | 08-25-2008 06:16 AM |
| Side by side frig keeps running | georgenglish | Refrigerator & Freezer Repair | 2 | 06-06-2008 09:08 AM |
| Kenmore 106. Frig Flashing -1 37 0; not running | DesertWanderer | Refrigerator & Freezer Repair | 9 | 12-14-2007 11:04 PM |
