Discuss
Bypassing Frigidaire Freezer Defrost Cycle
 in
Refrigerator & Freezer Repair
Hello! I have an old Frigidaire Freezer that I would like to convert into a refrigerator. I have a Johnson
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Bypassing Frigidaire Freezer Defrost Cycle
  #1 (permalink)
Old 01-25-2010, 08:30 PM
Junior Member
bgreg00 is on a distinguished road
Exclamation Bypassing Frigidaire Freezer Defrost Cycle
Model Number: MFU14F3GW5   Brand: Frigidaire   Age: 5 - 10 years
Hello! I have an old Frigidaire Freezer that I would like to convert into a refrigerator. I have a Johnson Controls Thermostat to set the temperature of the freezer at about 38F. Everything worked great for a couple of hours but then the temperature shot up to 50F and the compressor started to click on and off. At first I believed that the relay or the compressor was damaged. During my search for the relay, I discovered the defrost cycle timer. After fidgeting with the manual knob on the cycle timer I discovered that there were certain modes where the compressor behaved normally and other modes where the compressor cut in and cut out. Is it possible that the defrost cycle is interfering with my hardwired Johnson Controls Thermostat causing these bizarre compressor issues? Could somebody please teach me how what modes I am switching between with the defrost timer knob? Should the freezer always be on compressor mode for thermostat control to function properly? If so, is there any way I can bypass the timer so that the freezer doesn't start a defrost cycle?
I am making a lot of guesses and assumptions on not a whole lot of knowledge, so don't hold back if you think I might be barking up the wrong tree with this theory. Thank you!!
Ads By Google
Related Models
Frigidaire MFU14F3GW5 Frg(v0) / Freezer
Frigidaire MFU14F3GW6 Frg(v0) / Freezer
Frigidaire MFU14F3GW7
Frigidaire MFU14F3GW8
Frigidaire MFU14F3GW9 Frigidaire/freezer
Frigidaire MFU14F7FW0 Frg(v0) / Freezer
Frigidaire MFU14F7FW1 Frg(v0) / Freezer
Frigidaire MFU14M2AW0 Tap(v10) / Upright Freezer
Frigidaire MFU14M2AW1 Tap(v11) / Upright Freezer
Frigidaire MFU14M2AW2 Tap(v12) / Upright Freezer
Frigidaire MFU14M2BW0 Tap(v7) / Upright Freezer
Frigidaire MFU14M2BW1 Tap(v8) / Upright Freezer
Frigidaire MFU14M2BW2 Wwh(v0) / Freezer
Frigidaire MFU14M2BW3 Frg(v1) / Freezer
Frigidaire MFU14M2BW4 Frg(v0) / Upright Freezer
Frigidaire MFU14M2FW0 Frg(v0) / Freezer
Frigidaire MFU14M2FW1 Frg(v0) / Freezer
Frigidaire MFU14M2GW0 Frg(v0) / Freezer
Frigidaire MFU14M2GW1 Frg(v0) / Freezer
Frigidaire MFU14M2GW2 Frg/freezer
Frigidaire MFU14M2GW3 Frigidaire/freezer
Frigidaire MFU14M2GW4 Frigidaire/freezer
Frigidaire MFU14M2GW5 Frigidaire/freezer
Frigidaire MFU16F3BW0 Tap(v4) / Upright Freezer
Frigidaire MFU16F3BW1 Frg(v1) / Upright Freezer
Frigidaire MFU16F3BW2 Wwh(v0) / Freezer
Frigidaire MFU16F3BW3 Frg(v0) / Upright Freezer
Frigidaire MFU16F3BW5 Frg(v0) / Upright Freezer
Frigidaire MFU16F3BW6 Frg(v0) / Upright Freezer
Frigidaire MFU16F3BW7 Frg(v0) / Freezer
Frigidaire MFU16F7FW0 Frg(v0) / Freezer
Frigidaire MFU16F7FW1 Frg(v0) / Freezer
Frigidaire MFU17F3GW0 Frg(v1) / Freezer
Frigidaire MFU17F3GW1 Kel(v10) / Freezer
Frigidaire MFU17F3GW2 Kel(v11) / Freezer
Frigidaire MFU17F3GW3 Kel(v12) / Freezer
Frigidaire MFU17F3GW4 Frg(v1) / Freezer
Frigidaire MFU17F3GW5 Frg(v2) / Freezer
Frigidaire MFU17F3GW6 Frg(v0) / Freezer
Frigidaire MFU17F3GW8 Frigidaire/freezer
Frigidaire MFU17M3AW0 Tap(v7) / Upright Freezer
Frigidaire MFU17M3AW1 Tap(v8) / Upright Freezer
Frigidaire MFU17M3BW0 Tap(v4) / Upright Freezer
Frigidaire MFU17M3BW1 Frg(v1) / Upright Freezer
Frigidaire MFU17M3BW2 Wwh(v0) / Freezer
Frigidaire MFU17M3BW3 Frg(v0) / Upright Freezer
Frigidaire MFU17M3GW0 Frg(v0) / Freezer
Frigidaire MFU17M3GW1 Frg(v0)
Frigidaire MFU17M3GW2 Frg/freezer
Frigidaire MFU17M3GW3 Frigidaire/freezer
Frigidaire MFU20F3BW0 Tap(v4) / Upright Freezer
Frigidaire MFU20F3BW1 Frg(v1) / Upright Freezer
Frigidaire MFU20F3BW2 Wwh(v0) / Freezer
Frigidaire MFU20F3BW3 Frg(v0) / Upright Freezer
Frigidaire MFU20F3BW4 Frg(v0) / Upright Freezer
Frigidaire MFU20F3BW5 Frg(v0) / Upright Freezer
Frigidaire MFU20F3BW6 Frg(v0) / Freezer
Frigidaire MFU20F3GW0 Frg(v0) / Freezer
Frigidaire MFU20F3GW1 Frg(v0) / Freezer
Uni MFU20F3GW10 Universal/freezer
Frigidaire MFU20F3GW2 Frg(v1) / Upright Freezer
Frigidaire MFU20F3GW3 Frg(v2) / Upright Freezer
Frigidaire MFU20F3GW4 Frg(v3) / Upright Freezer
Frigidaire MFU20F3GW5 Frg(v0) / Freezer
Frigidaire MFU20F3GW6 Frg(v0) / Freezer
Frigidaire MFU20F3GW7 Frg(v0) / Freezer
Frigidaire MFU20F3GW8 Universal/frzr
Frigidaire MFU20F3GW9 Frigidaire/freezer
Frigidaire MFU20F7FW0 Frg(v0) / Freezer
Frigidaire MFU20F7FW1 Frg(v0) / Freezer
Frigidaire MFU21M3AW0 Frg(v1) / Upright Freezer
Frigidaire MFU21M3AW1 Frg(v2) / Upright Freezer
Frigidaire MFU21M3BW0 Tap(v7) / Upright Freezer
Frigidaire MFU21M3BW1 Tap(v8) / Upright Freezer
Frigidaire MFU21M3BW2 Wwh(v0) / Freezer
Frigidaire MFU21M3BW3 Frg(v0) / Upright Freezer
Frigidaire MFU21M3BW4 Frg(v0) / Upright Freezer
Frigidaire MFU21M3GW0 Frg(v0) / Freezer
Frigidaire MFU21M3GW1 Frg(v1) / Upright Freezer
Frigidaire MFU21M3GW2 Frg(v2) / Upright Freezer
Frigidaire MFU21M3GW3 Frigidaire/freezer
Whirlpool MFW9600SQ0 Automatic Washer
Maytag MFW9600SQ0 Automatic Washer
Whirlpool MFW9600SQ1 Automatic Washer
Maytag MFW9600SQ1 Automatic Washer
Whirlpool MFW9700SB0 Automatic Washer
Maytag MFW9700SB0 Automatic Washer
Whirlpool MFW9700SB1 Automatic Washer
Maytag MFW9700SB1 Automatic Washer
Whirlpool MFW9700SQ0 Automatic Washer
Maytag MFW9700SQ0 Automatic Washer
Whirlpool MFW9700SQ1 Automatic Washer
Maytag MFW9700SQ1 Automatic Washer
Maytag MFW9800TK0 Automatic Washer
Maytag MFW9800TQ0 Automatic Washer
Maytag MFX100PAVS Washer - Top Loading
Maytag MFX50NNATS Washer - Horizontal Axis
Maytag MFX50PNAVS Washer - Horizontal Axis
Maytag MFX75PNAVS Washer - Top Loading
Maytag MFX80PNAVS Washer - Top Loading
Maytag MFX95PNAVS Washer - Top Loading
Whirlpool MG2070XAB0
Whirlpool MG2070XAQ0
Thermador MG29EAP
Whirlpool MG3090XAB0
Whirlpool MG3090XAQ0
Whirlpool MG3090XBB0
Whirlpool MG3090XBQ0
Whirlpool MG8120XDB0
Whirlpool MG8120XDQ0
Maytag MGC5430ADB Surface Unit - Gas
Maytag MGC5430ADC Surface Unit - Gas
Maytag MGC5430ADQ Surface Unit - Gas
Maytag MGC5430ADW Surface Unit - Gas
Maytag MGC5430BDB Surface Unit - Gas
Maytag MGC5430BDQ Surface Unit - Gas
Maytag MGC5430BDS Surface Unit - Gas
Maytag MGC5430BDW Surface Unit - Gas
Maytag MGC5536BDB Surface Unit - Gas
Maytag MGC5536BDQ Surface Unit - Gas
  #2 (permalink)
Old 01-28-2010, 08:55 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here is a wiring diagram Note it is for a GW7, I could not find one for a GW5
http://manuals.frigidaire.com/prodin...ud/2165839.pdf
Possibly but I do not know how you wired your new thermostat into the unit.
It is either defrost heater on or compressor and fan on.
I am assuming from looking at the parts breakdown that this is an evaporator fan used to circulate the air in the unit over the evaporator coils.
Not sure what you mean here.
Looks like the thermostat not only controls the compressor but also the defrost timer motor so if the thermostat is not closed the timer will never advance out of the defrost cycle and move to the compressor run side of the defrost relay.
Yes it is possible just place the timer cam in the center of a cool cycle and disconnect the timer's motor. Problem is you will have to manually defrost the unit.
The problem is that the food in the freezer acts like a large cold reservoir so this stabilizes the temperature. With that removed you are likely to have fast temperature swings as it tries to regulate the temperature. Also you compressor is on full or totally off so that will also contribute to fast cycling. It also depends on the temperature variation of your new thermostat. For instance it it opens at 35 and closes at 35.5 it will cycle quickly forever.
Also there is a problem with the temperature gradient in the unit since the fan only circulates when the compressor is on you could find it much warmer at the top of the unit as the cold air will drop to the bottom.
Looks like you may have some experimenting ahead of you.
__________________
  #3 (permalink)
Old 01-28-2010, 04:56 PM
Junior Member
Default
Thanks for the response! Now that I understand that I would have to manually defrost the freezer, I have lost my desire to bypass the defrost timer. The situation has changed a little since my last post. Currently the freezer is working. What seems strange to me is how unreliable this freezer is. It will work beautifully for a few hours and then the compressor will seize up and exhibit symptoms of a burnt relay. The temperature shoots up and the compressor will click on (dimming the lights) run for 5 seconds and than halt with another click. Normal compressor action does not dim the lights in my apartment. Oddly, the way I fix this problem is to give the defrost cycle a very imprecise spin, and for some reason the compressor starts to behave normally again.
The Johnson Controls thermostat is external. It controls the temperature by opening and closing the connection to the wall socket. The Thermostat senses the temperature with a wired probe. I have the thermostat set at 38F. Now that you understand my external thermostat setup do you think that this setup could interfere with the normal defrost cycle and cause my freezer to behave this way?
I am confused by your cold reservoir comment. Are you saying that it will be difficult to use a freezer as a refrigerator because a freezer compressor is usually has the help frozen foods to stabilize the temperature? I do have a large metal keg inside the freezer... will that help maintain the temperature?
Have you ever heard of anybody fixing compressor halting by advancing the defrost timer?
  #4 (permalink)
Old 01-29-2010, 06:47 AM
Senior Expert
APP Volunteer
Default
I have never done this so am just throwing out possible problems/solutions.
I sat down and gave this another think.
I looked at your unit parts and this is what I would do if I was tackling this.
I would remove the cover from the evaporator coil. It should then not hold the cold air in this area and therefore you should not need to defrost it as it should melt off any frost due to your thermostat's set temperature.
I would then by pass the timer and internal thermostat by connecting the yellow wire from the compressor and fan (see wiring diagram directly too your power cord (black).
Be sure that you new thermostat can handle at least 15 amps.
You may have to jiggery pokery a mount for the evaporator fan so it pulls air through the evaporator coils.
Could be the unit is on it's last legs but your fix of spinning the defrost cam may also indicate that the defrost timer contacts are pitted and not making good contact all the time. This would then drop the voltage to the compressor and it would draw more current trying to start up.
Yes. On most fridges you measure the temp in the fresh food but is is fed by the cold air from the freezer so the food in the freezer acts as a cold supply so it does not turn on the compressor as often. Hope this makes sense!
Only time will tell if this will work but your keg should act as a heat sink to stabilize the temperature the same as the food in the freezer
No but see above. It also could be the relay.
Another possibly important point is where you locate the thermostat's sensor.
I would start in the vertical center of the unit first.
Would be a good idea to get a thermometer so you can check the temperatures at the top and bottom of the unit.
You do not want it freezing on the bottom of the keg. If the keg is near full the liquid should circulate by itself to prevent freezing but if the keg is near empty it could freeze.
One other thought I had is you may want to get a small pancake fan and put it in the freezer letting it run all the time so it circulates the air and prevents temperature gradients. You would not need much air flow so should be efficient as far as electrical use.
PS: I love doing things like this. At the lake my fridge is a fridge in summer and a hot box in winter so I do not have to hump everything back (that may freeze and explode) to the city.
Hope this helps, good luck and have fun.
__________________
  #5 (permalink)
Old 01-30-2010, 12:04 PM
Junior Member
Default
Thank you so much for the help denman! I am going to start by learning a little more about the temperature gradient in my freezer with a thermometer. I am also going to take another look at the contacts on the defrost timer and try to make a better connection. I have had the problem once since my last post, but I quickly fixed it by advancing the timer. Do you think that ordering new defrost timer might help? I'm a little hesitant to get my hands dirty with the bypass operation, but soon I will have to do something.
  #6 (permalink)
Old 01-30-2010, 03:25 PM
Senior Expert
APP Volunteer
Default
It could but I cannot be 100% sure, just seems to me that if playing with the timer fixes the problem then it is the most likely culprit.
The only way to tell for sure is to measure across the defrost timer contacts when it is happening. If you see a voltage there then you know that the contacts are dropping the voltage to the compressor and causing the problem.
Note if you are going to leave the defrost timer in circuit do not remove the evaporator cover as will cause too much heat to go into the main compartment.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Defrost problem in Frigidaire freezer hskang Refrigerator & Freezer Repair 0 07-25-2009 02:37 PM
Freezer Thaws In Defrost Cycle Chitcharney Refrigerator & Freezer Repair 3 06-04-2009 05:39 PM
Frigidaire: Freezer will not Defrost dbolan Refrigerator & Freezer Repair 4 05-07-2009 07:04 AM
Amana Bottom Freezer Defrost Cycle Help harryhoudini Refrigerator & Freezer Repair 5 12-30-2008 08:07 PM
freezerless frigidaire defrost cycle pmagee Refrigerator & Freezer Repair 3 04-01-2008 09:05 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
