Discuss
Amana side by side hot between doors
 in
Refrigerator & Freezer Repair
I just noticed that on our Amana side by side that it is getting real hot on the strip between
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana side by side hot between doors
  #1 (permalink)
Old 04-13-2008, 12:16 PM
jdahunt jdahunt is offline
Junior Member
jdahunt is on a distinguished road
Default Amana side by side hot between doors
Model Number: SCD25TL   Brand: Amana   Age: 5 - 10 years
I just noticed that on our Amana side by side that it is getting real hot on the strip between the doors. The fridge side is working ok but the freezer side isn't as cold as it should be. Any ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-13-2008, 12:29 PM
gearhead1218 gearhead1218 is offline
Member
gearhead1218 is on a distinguished road
Default
I could be wrong here, but I think Amana runs the high side refrigerant line through that area to prevent condensation build-up.
If that is the case, then most likely you need to do a GOOD cleaning of your condenser that is located on the bottom of the unit. Also check in the back of the unit to make sure the fan motor located near the compressor is operating properly.
  #3 (permalink)
Old 04-13-2008, 02:04 PM
Junior Member
Default
gearhead the condenser was definately dirty and needed to be cleaned. I also notice that the fan down there is hard to turn and never comes on, am I right in assuming that it should be changed too?
  #4 (permalink)
Old 04-13-2008, 06:19 PM
Member
Default
Fan needs to be replaced.
Hopefully the compressor is not damaged from the excessive heat.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana side-by-side refrigerator ice maker. Larry.Jenkins Refrigerator & Freezer Repair 1 01-28-2008 01:00 PM
Amana side by side freezer not cooling gunner Refrigerator & Freezer Repair 1 12-03-2007 04:30 PM
amana SDC25TL side by side coil frozen..why? weel Refrigerator & Freezer Repair 3 11-19-2007 09:14 PM
Amana Side by Side Refrigerator Evaporator Fan Question beachesfour Refrigerator & Freezer Repair 1 10-17-2007 04:10 AM
Amana Side by Side Refrigerator Freezer MFG. P1317202WE josephbowles@earthlink.ne Refrigerator & Freezer Repair 0 08-10-2007 06:38 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
