| » refriderator door won't close |
Model Number: PTB2153GRW Brand: Maytag Age: More than 10 years
My refridgerator door won't shut, I thought it was the seal but just looking a bit at this site, it looks like it might have something to do with the door. The freezer door above it works fine so maybe not a leveling problem. My food keeps freezing and it's costing me so much money, electricity and food. HELP.
Typically what will cause this is the little plastic spacers under the door on the hinge pin will break off. Sometimes installers leave them off and after a while the door will not close.
This will cause the door to drop down and the door will not close. It is best if you order the correct spacer but whatever you do, do not use a metal spacer. Also make sure nothing is hitting the door. Refrigerator Door Repair Guide |
Other common problems are the gasket on the bottom of the door is damaged and not sealing, or the gasket just peals away from the fridg frame.
If the first, you will need a new door gasket. If the second, make sure the door gasket is still "soft", then duck tape the door shut overnight, should seal ok next morning when the tape is removed.
__________________
| Display Modes | |
| ice door will not close on fountain door unit | wesi | Refrigerator & Freezer Repair | 0 | 12-07-2009 05:26 PM |
| Replaced Door seal, door wont close | ggreen3 | Dishwasher Repair | 3 | 12-18-2008 09:17 AM |
| Door doesn't close all the way. | Dan Cornett | Oven Repair (including Ranges and Cooktops) | 0 | 06-16-2008 12:52 PM |
| My Oven Door Latch Won't unlock so the door won"t close | Victorine Ravenell | Oven Repair (including Ranges and Cooktops) | 1 | 11-14-2007 10:40 AM |
| door doesn't close so seal is making contact all around door | d ahern | Refrigerator & Freezer Repair | 0 | 10-08-2007 06:44 AM |
