Discuss
Freezing Up
 in
Refrigerator & Freezer Repair
First the freezer would not go below 9 degrees. Zero normal. Turned it off for 30-60 minutes and it
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezing Up
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-11-2008, 08:55 PM
lsdobyns lsdobyns is offline
Junior Member
lsdobyns is on a distinguished road
Question Freezing Up
Model Number: PSF26NGTB BB   Brand: GE   Age: 1 - 5 years
First the freezer would not go below 9 degrees. Zero normal. Turned it off for 30-60 minutes and it seemed to work again. Also would make ice very slowly.
I seems to freeze up every 20-24 hours. I have a temp prob in the freezer. It will drop to -8 degrees during the first 6-12 hours. Then later no lower than 15 degrees.
I have checked the fans, inside and outside. Working.
I found the diagram and measured the defrost heater. (blue and orange wires on the main board). It seems good.
The compressor seems to pull the temp down quickly.
I had replaced the ice maker five months back.
It sounds like it is not running a defrost cycle. How often should it run a cycle?
Could it be the main board, item 801?
Suggestions.
Lee
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE refridgerator Freezing food in Fridge and freezing water line niloa Refrigerator & Freezer Repair 0 04-09-2008 08:59 AM
freezing everything lkratzer200@yahoo.com Refrigerator & Freezer Repair 0 12-29-2007 02:53 PM
ice maker freezing up coneman Refrigerator & Freezer Repair 1 12-14-2007 03:23 PM
Sub Zero 201 FD Freezer is not freezing and coils are frosting over/freezing up badace Refrigerator & Freezer Repair 1 12-02-2007 09:54 AM
freezing everything camodio Refrigerator & Freezer Repair 1 10-15-2007 03:58 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
