| » Defrost drain continues to freeze up |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: 106.71182100 Brand: Kenmore Age: 5 - 10 years
Hi Guys, We bought this refrigerator new from Sears about 6.5 years ago. We never had a problem with it until 3 months ago when we found water on the top shelf and under the crisper.
I then found your repair forum, and from there, I removed the interior freezer panels, thawed the frozen water trough and frozen drain opening using a hair dryer. I then poured hot water through the drain tube which ran immediately into the catch pan underneath the refrig. I also pushed plastic trimmer string through it as well. Then, a month later it froze up again, and I performed the same procedures a second time. Now, another month later, it’s froze up for a third time. I’m about to hang a can under the vent between the freezer & refrig. Is there anything I can do, or buy from you guys, to fix what has turned into a monthly problem? Thank you. Keith |
| Display Modes | |
| Defrost Drain Freezing | reynolds1 | Refrigerator & Freezer Repair | 3 | 01-06-2008 12:35 PM |
| Clogged defrost drain tube | d77n | Refrigerator & Freezer Repair | 0 | 12-15-2007 09:30 AM |
| Amana Refrigerator drain freeze problem | Scottrse1 | Refrigerator & Freezer Repair | 2 | 12-09-2007 07:20 AM |
| defrost drain pan repeatedly overfilling | j13 | Refrigerator & Freezer Repair | 5 | 12-08-2007 02:20 AM |
| Dryer turns on,continues to run | lagerman1 | Dryer Repair | 3 | 10-26-2007 02:44 PM |
